S2000 filter fit a GSR motor...?
Old May 29, 2005 | 08:42 PM
EJK20R's Avatar
Default S2000 filter fit a GSR motor...?
does anyone use the S2K filter on a GSR....? and what is the experiance ...?
Old May 29, 2005 | 08:47 PM
Haleiwa-Brando's Avatar
Default Re: S2000 filter fit a GSR motor...? (EJK20R)
Out of curiosity...why would one do this? If you say more HP, I want to see dyno plots.
Old May 29, 2005 | 08:55 PM
Yambor's Avatar
Default Re: S2000 filter fit a GSR motor...? (Haleiwa-Brando)
Not completely 100% sure but i think they use the same filter as a gsr..
Old May 29, 2005 | 09:04 PM
EJK20R's Avatar
Default Re: S2000 filter fit a GSR motor...? (JH4DC4-2GSR)
I just wanted to know anyone else have experiances ...? good idea or bad ...?
Old May 29, 2005 | 10:12 PM
Thrasher's Avatar
i dont claim to know anything about s2000's, but........ no
the filter is like 2 feet by 3 feet well not hardly, but that thing is freakin huge! where would you fit it in your gsr?
Old May 29, 2005 | 11:04 PM
reza
Default Re: S2000 filter fit a GSR motor...? (Thrasher)
I heard some thing about the oil pressure being higher then a gsr's? or lower... one of the two.
Old May 30, 2005 | 06:27 AM
Racermech's Avatar
Default Re: S2000 filter fit a GSR motor...? (reza)
oil filter??? air filter??? fuel filter????
The oil filter is a little smaller and is supposed to increase oil preasure. I have also heard that hinda now only offers small filters, which is the same size as the s2000.
This has been covered a few times here, do a search for oil filters and the s2000 filter will come up
Old May 30, 2005 | 08:34 AM
boostinb20vtec's Avatar
i work at a Honda dealership and NO they are not interchangeable. The S2000 filter is larger in outerdiameter and the oil seal is not the same. The filter for your GSR has a smaller outer diameter than the S2000 filter and the oil gasket on the filter is a smaller diameter as well. Honda used to make larger capacity oil filters for the other motors, but now as some one stated, they only make the smaller filters for most engines, the exceptions being the S2000(which has a larger filter) and the insight(which has a super small filter)
Old May 30, 2005 | 09:04 AM
shythappenz's Avatar
yes! s2000 oil filters fit and b series and d series. and yes there alot bigger then the normal b and d series oil filters. but the s2000 oil filter flows better
Old May 30, 2005 | 09:44 AM
Yambor's Avatar
Default Re: (shythappenz)
Well also you can use RSX oil filters, The filters are slightly smaller and allow higher oil pressure.
Old May 30, 2005 | 09:48 AM
dom93hatch's Avatar
It will fit, but what's the point? You won't be able to tell the difference. They will still work either way.
Old May 30, 2005 | 11:39 AM
CNSK's Avatar
Default Re: (dom93hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dom93hatch &raquo;</TD></TR><TR><TD CLASS="quote">It will fit, but what's the point? You won't be able to tell the difference. They will still work either way.</TD></TR></TABLE>
my thoughts exactly...
Old May 30, 2005 | 12:16 PM
Presto800's Avatar
Why would you do this ? I believe you get the same result...
Old May 30, 2005 | 12:55 PM
quiksheit's Avatar
Default Re: (Presto800)
I think it was on bobistheoilguy.com (the home oil of complete oil nutcases) that i saw numerous posts about this. The name of the game is increased filtering media. It is like doin the oil filter relocation kit and using gigantic ford filters. You get more oil, cooler running, more filtering, and more oil capacity which = more time before it goes bad.
You guys were quick to shoot this idea down.
Engine rebuilders have been talking about this for the longest time.
Old May 30, 2005 | 03:05 PM
LSvtec03's Avatar
Default Re: (boostinb20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostinb20vtec &raquo;</TD></TR><TR><TD CLASS="quote">i work at a Honda dealership and NO they are not interchangeable. The S2000 filter is larger in outerdiameter and the oil seal is not the same. The filter for your GSR has a smaller outer diameter than the S2000 filter and the oil gasket on the filter is a smaller diameter as well.</TD></TR></TABLE>
you work there doing what? janitor?
the s2000 filter is the exact same size as the gsr (not the new smaller ones). s2000 filters use a different filter element as they are made in japan as opposed to the fram or whatever element they switched to now.
also, the s2k filter has a valve preventing oil back flow. i don't remember if they all have it or not.
shawnlee250
Honda Civic (2001 - 2005)
Aug 3, 2011 12:54 AM
HyphyBB6
Oct 21, 2008 09:40 PM
xintegr
Aug 29, 2007 06:46 AM
vlballa
May 7, 2007 04:58 AM
020
Jan 31, 2004 09:37 AM
