how do you get low ohms?
Old May 29, 2005 | 07:32 PM
blindO's Avatar
Default how do you get low ohms?
how do you get .5 ohms,1 ohms, 2ohms? these ohms are for both speakers and subwoofers. this will help my system guys.
Old May 29, 2005 | 08:07 PM
Loccusst's Avatar
If you don't know then I am not sure you should be messing around going that low. Can your amp or amps handle that low of ohm? Simpley take all the positives of the speakers and hook them up to the positive on the amp and do the same with the negative. The more speakers you add to one channel the more the ohm drops. Two four ohm subs together make a two ohm load on the amp. Two two ohm subs will make a 0ne ohm load on the amp.
Old May 30, 2005 | 07:21 AM
DREID's Avatar
list your equipment
and it sounds like you are gonna run your speakers and subs off the same amp, not a good idea
GetawayInMoscow
Audio / Security / Video
Apr 13, 2009 02:41 PM
imadigitalgod
18
May 13, 2008 04:00 PM
mmajedi
Nov 5, 2007 08:45 AM
Orpheus1985
Jul 21, 2005 07:15 AM
juniordc2
12
Jun 4, 2002 11:07 PM
