viper 791xv issue
Old May 29, 2005 | 06:51 PM
myhatchisstuck's Avatar
Default viper 791xv issue
Ive recently noticed that my viper doesnt transmit when the shock sensor goes off, it does not trasmit a warning to my LCD remote. I know the transmission from the car is not completely dead because the remotes still let me know if my dooor or trunk is not closed when i arm.
Could it be the settings? Reprogram?
Anyideas?
thanks
Old May 29, 2005 | 08:21 PM
Loccusst's Avatar
It should tell you by beeps and the little icon on the remote. I would say it might be the remote and not the alarm itself. Take it to the shop you got it installed and see what they say. Did it ever tell you and how long have you had the alarm.
Old May 29, 2005 | 08:32 PM
Default Re: (Loccusst)
yea it used to tell me, i had a battery go bad(low) and i had to hook up a new battery. In the meantime however i was playing with the valet button radomly.
It tells me that the car has been jacked with, after i disarm.
It just doesnt tell me when the alarm is triggered. Other than that every notiffication is working fine.
Old May 29, 2005 | 10:15 PM
JDM PRO's Avatar
Default Re: (myhatchisstuck)
stop messing w/ the remote if you don't know what you are doing. Hold all four buttons simultaneously until one long beep is heard. Then hold * within five seconds to toggle the page mode(ON OR OFF)
Old May 30, 2005 | 07:31 AM
I do the setup on my remote everytime to i change the AAA, i might have pressed the * accidently.
THe battery that went bad was my car battery, when it went low, i got a jump and the alarm stoped synching, that was when i panicked and start playing with the valet button in the car. But after i disconnected the battery and reconnected it the remote synced up fine.
But anywho, it now works. thanks all
Old May 30, 2005 | 07:59 PM
JAI-DM's Avatar
Lately at my shop (Car Toys) We have been doing a lot of defecitive swaps on Two way DEI alarms. Usually the brain is not sending responder signals back to the remote. Go have your brain swapped. It has a lifetime warranty.
jai
Old May 31, 2005 | 05:13 AM
Loccusst's Avatar
We have had some similar issues at the shop I work at. We found sometimes it was the antenna not the brain box. Glad it was just a programing problem and everything is ok.
Old Jun 2, 2005 | 04:06 AM
superthug's Avatar
anyone got the installation manual for this alarm.
JBB93Coupe
14
Jun 16, 2009 02:11 PM
bmwracer316
Mar 7, 2007 11:14 AM
Knight1
Audio / Security / Video
Aug 31, 2005 10:37 AM
dukers
Jul 18, 2005 05:39 PM
BringIT
Dec 27, 2001 07:50 PM
