Arc welder shocking??
Old May 29, 2005 | 06:35 PM
AZNracerx1989's Avatar
Default Arc welder shocking??
Will it shock me if I touch the metal with my bare hands?? since electric is going through it??
Old May 31, 2005 | 02:01 AM
Sifu's Avatar
Yes it will, only way around this is to weld naked since then there will be no static charge build up between your skin and clothes...
Old May 31, 2005 | 06:05 AM
david@didrace.com's Avatar
Default Re: Arc welder shocking?? (AZNracerx1989)
It won't shock you unless you are completing the weld circuit (one hand on the electrode and the other on a ground). You should be wearing welding gloves anyways so it shouldn't be a problem.
Old May 31, 2005 | 10:34 PM
spoonh8ta's Avatar
Default Re: (Sifu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sifu &raquo;</TD></TR><TR><TD CLASS="quote">Yes it will, only way around this is to weld naked since then there will be no static charge build up between your skin and clothes...</TD></TR></TABLE>
very true
the is a little screw on mine that i have touched before and it gives me a nice little shock
TEGNO1
Welding / Fabrication
16
Jan 18, 2007 02:18 AM
2.2SICKLUDE
Apr 28, 2005 04:37 PM
Surewin
Feb 1, 2005 08:35 PM
nocsyn
16
Nov 10, 2004 07:09 AM
DIYaccord
60
Apr 30, 2004 02:29 PM
