SRZ RACING stock block GSR build
Old May 29, 2005 | 12:36 PM
VtecKiDD's Avatar
Default SRZ RACING stock block GSR build
DFE Enterprises Head
all going in this
BUILD CONSISTS OF:
Rocket Motorsports M22x Camshafts
Rocket Motorsports BVTEC Valvesprings and Retainers
Skunk2 Cam Gears
SMSP 4-2-1 Production Header
Blox Intake Manifold
RPM SERVICE 70mm Throttle Body
Password JDM Fake Js intake
DFE ENTERPRISES Stage 1 Headwork
Omnipower Valves
GSR HEAD
STOCK OEM GSR BLOCK
hoping for 190whp. we'll see. stay tuned as we put it on the dyno this week
Old May 29, 2005 | 01:14 PM
5STAR3's Avatar
Default Re: SRZ RACING stock block GSR build (VtecKiDD)
good luck
Old May 29, 2005 | 01:26 PM
moto1320's Avatar
Default Re: SRZ RACING stock block GSR build (envision2teg)
Staying with the stock pistons?
Old May 29, 2005 | 01:59 PM
flesh199's Avatar
obd1 p72???
detail about ecu...
Old May 29, 2005 | 02:16 PM
ex2gsr's Avatar
Default Re: (flesh199)
yes obd1 chipped p72....***** gunna be hawt
Old May 29, 2005 | 02:17 PM
ex2gsr's Avatar
Default Re: (ex2gsr)
and yes fully stock gsr block...its all in the head baby!
VtecKiDD's Avatar
100% stock block, stock GSR block, stock pistons.
OBD1 ECU with CROME
Old May 29, 2005 | 04:13 PM
six7one's Avatar
subscribed
Old May 29, 2005 | 04:29 PM
91' LS-VTEC's Avatar
Default Re: -------------------
I think you'll pull it off.
Old May 29, 2005 | 04:51 PM
SMSP's Avatar
Save the TB and just go with an ITR TB.
Old May 29, 2005 | 05:03 PM
mtber's Avatar
Good luck.
I don't see you making 190s with 10.0:1 c/r unless the dyno reads high
Old May 29, 2005 | 05:50 PM
xtrafastcivic's Avatar
Default Re: (mtber)
the head can be milled...
Old May 29, 2005 | 06:03 PM
itgsr98's Avatar
Default Re: (XtraFastCRX)
i think 190 is possible. w/ flat faced valves and two layer head gasket comp. will be more then 10.0.1
Old May 29, 2005 | 06:06 PM
SMSP's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Good luck.
I don't see you making 190s with 10.0:1 c/r unless the dyno reads high </TD></TR></TABLE>
Remember he's got Rocket's cams and that intake which has proved to work on a dyno.
Old May 29, 2005 | 07:12 PM
ex2gsr's Avatar
Default Re: SRZ RACING stock block GSR build (SMSP)
why just go with an itr Tb instead of a 70mm rpm tb dave?
Old May 29, 2005 | 07:31 PM
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">Save the TB and just go with an ITR TB.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex2gsr &raquo;</TD></TR><TR><TD CLASS="quote">why just go with an itr Tb instead of a 70mm rpm tb dave?</TD></TR></TABLE>
yea, why do that?
also, does an ITR fit on a GSR manifold, are they all interchangeable?
Old May 29, 2005 | 07:48 PM
puregroove's Avatar
Default Re: (six7one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by six7one &raquo;</TD></TR><TR><TD CLASS="quote">subscribed</TD></TR></TABLE> +1
Old May 29, 2005 | 07:50 PM
A1's Avatar
A1
yea, why do that?
ITR THROTLE BODY IS GOOD ENOUGH.OR BOREOUT THE STOCK GSR.70MM IS TO BOG FOR YOUR SET UP.
ITR TB WILL FIT ON GSR MANIFOLD.THEY ARE INTERCHANGEABLE.EVEN THE S2000 TB.
Old May 29, 2005 | 07:57 PM
EVIL Hx Coupe's Avatar
Default Re: SRZ RACING stock block GSR build (d16why8)
I'm planning to have my GSR head built pretty soon. Nice to see someone doing something similar so I have an idea of what I should get.
subscibed!
Goodluck!
Old May 29, 2005 | 08:03 PM
SMSP's Avatar
Because the ITR is big enough. I have to run stock TB for H1 so we used the ITR of course. With an engine dyno header and minimal tuning we were already at 247bhp, it will probably go to 260 with the right header and tuning.
So if the ITR TB can make the power why spend the money on something else? Plus you lower the intake velocity going into the IM with a bigger TB.
I also think you can make this argument with injectors, why go bigger if what you have is withing limits? I think a longer duration for the injector cycle will promote better mixing than a shorter duration from a larger injector.
Old May 29, 2005 | 08:09 PM
VtecKiDD's Avatar
I have a 62mm and that 70mm TB here, we shall see what works. **** it, if we are off, i sense some ITBs going on
Old May 29, 2005 | 08:13 PM
SMSP's Avatar
Nothing beats the sound of the ITBs as you are aware.
Old May 29, 2005 | 08:21 PM
VtecKiDD's Avatar
MWAHAHAH
ITBS and SMSP
Old May 29, 2005 | 08:24 PM
SMSP's Avatar
I just loved my 40mm Mikunis and then the 45mm Webers. Induction sounds are better than exhaust on these 4 bangers, but what about ITBs and a V8...ahhhhhhhhh.
SMSP - Who leaves to go find the Hans' video in the V8 Bimmer.
Old May 29, 2005 | 08:25 PM
VtecKiDD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">I just loved my 40mm Mikunis and then the 45mm Webers. Induction sounds are better than exhaust on these 4 bangers, but what about ITBs and a V8...ahhhhhhhhh.
SMSP - Who leaves to go find the Hans' video in the V8 Bimmer.</TD></TR></TABLE>
stop teasing dave
