2.2L b16 with deck plate!!!
tech43 has a kit for the b16 to be able to run 2L+ by using a shortened 85mm custom pistons with ls crank and rods to clear the head.
is it possible to add a deck plate on the b16 to run the same tech43 shortened piston kit with ls or custom rods and 95mm crank???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10w »</TD></TR><TR><TD CLASS="quote">what is perfect r/s again???</TD></TR></TABLE>
Misinformation and speculation here we come
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping »</TD></TR><TR><TD CLASS="quote">the ideal is 1.74</TD></TR></TABLE>
Can you explain why 1.74 is the idea r/s ratio?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation »</TD></TR><TR><TD CLASS="quote">
Can you explain why 1.74 is the idea r/s ratio?</TD></TR></TABLE>
what the **** is your problem.are you like a mr. know it all?
if you want to know why 1.74 r/s ratios are ideal look it up in the archives...do you see honda going any higher w/a factory production motor...
I just figured if you were going to make a recomendation about the "ideal" r/s ratio youd at least know why it would be considered ideal...
I mean, maybe you know something that the worlds fastest all motor cars dont???
1.4X-1.5X seems to work just fine for them
Id just like an explination, thats all... No harm in that
The Honda 1600 "R' that they use in Japan and Europe and for their 1.6 racers has a 1.83 R/S ratio so I guess they do know, they have improved the old one they coppied from the 1970's Cosworth 1.6 engines.
because at the track r/s don't mean squat....you only drive the car a 1/4 mile at a time.it is not just based on one thing.i for one am not really good at explaining..things like you want them to be explained.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping »</TD></TR><TR><TD CLASS="quote">that is what every b16 has,unless it is stroked.</TD></TR></TABLE>
That's what the B16A has. The B16B with it's taller deck has a ratio close to ~1.84 (going off memory here).
