92 - 95 honda civic
Old May 29, 2005 | 10:54 AM
shyxboy's Avatar
Default 92 - 95 honda civic
can anyone help me, if there isnt a spark or fuel when i try to turn on the car what would be the cause of this??? everything powers up there isnt an alarm and i'd check to see if there power to the distributer and also i jump'd the fuel relay and there isnt power... the power to the distributer but it dosent go though to the spark plugs???
Old May 29, 2005 | 10:56 AM
Archidictus's Avatar
Unceasing Measure
Default Re: 92 - 95 honda civic (shyxboy)
Main relay. It's under your dash on the driver's side and it's a common problem in our cars.
Old May 31, 2005 | 09:34 PM
shyxboy's Avatar
Default Re: 92 - 95 honda civic (Archidictus)
what if its not the main relay, i'd change the main relay under the dash but then it only cranks but it dosent turn on????? anyone ever has this problem... and there is not power to the fuel pump but there is power to the disturbor, what controls the fuel pump beside the main relay???
Old May 31, 2005 | 10:32 PM
NotSoSimple's Avatar
There should be a fuel pump fuse and/or relay. Can't remember..Too late.. Look for one of those. Do you have a Fuel Pump kill switch anywhere?
Old May 31, 2005 | 10:35 PM
Status Sean's Avatar
Default Re: 92 - 95 honda civic (NotSoSimple)
bad ecu????
Old May 31, 2005 | 11:20 PM
stevenlo's Avatar
have you check the main relay?
also make sure the distributor is pulsing.
Old Jun 1, 2005 | 08:09 AM
shyxboy's Avatar
Default Re: 92 - 95 honda civic (stevenlo)
no i dont think its the ecu... i've check the main relay and i'd changed it over to and it still dosent turn over...
BTaylor
May 29, 2022 03:35 AM
Hightower350
17
May 10, 2013 03:53 PM
david542
30
Jul 20, 2007 03:41 PM
95turboeg
Jul 7, 2006 11:38 AM
Steve
Aug 29, 2001 06:38 PM
