big brake kit for 99 civic
A GSR front and rear disc brake upgrade would be a wiser choice unless you already have an Si. You could even just get front GSR brakes and use the 02-03 SI rear disc brake setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">A GSR front and rear disc brake upgrade would be a wiser choice unless you already have an Si. You could even just get front GSR brakes and use the 02-03 SI rear disc brake setup.</TD></TR></TABLE>
Or if he wants bigger calipers...you can use Legend Calipers which are 2-pot and I belive Prelude Rotors.
All you need to do is grind down the caliper mounting bracket to be flush
well the problem is I'm in germany right now and i'm not an expert but i'm trying to learn more bout my civic so I was trying to figure out what would be my best bet for the brakes
and also good websites?
Well you have a few options
you can buy a "big brake kit" and it will only include a larger rotor and I think bigger brake pads. AEM sells that kit.
If you have the money you can upgrade to a real big brake kit which will inlude a larger 2/4 pot caliper, rotor, pads and the rest you need to install it.
Remember tho...the larger the caliper and rotor the larger wheels you will need. Some kits requre you to run 17" rims since the caliper will rub with any less.
Good luck man
AEM
BAER
Wilwood all make brake upgrades
check them out
Good luck man
AEM
BAER
check them out
well i have 17's on already so i was just trying to figure out which one
i was looking at the aem big brake kit and other kits also so maybe i'll go with the aem one.
Thanks for your help!
No I don't have them. Can't afford them since I am a poor college student. If I was into autocross or something I'd think about it. I'm ridin stock. I have rode in a hatchback with that kit and it could stop a hell of a lot better than mine.
tmeracz
Apr 26, 2006 06:35 PM
ooairewreckoo
Jul 4, 2005 06:07 PM
MrEg
Dec 6, 2003 07:53 PM
