ECU CODES??
Old May 29, 2005 | 08:33 AM
JDMJNKY's Avatar
Default ECU CODES??
Good Morning everyone! I hope you all are being safe this wknd...
Anyways back to the topic, my wifey & I have been lucky to add a 96 ex Vtec to our collection of cars... but the check engine light is on!! can someone give me some info. on where & how to get that code out the ECU???
P>S IT WAS FREE-99....I'll post picks once I clean the engine bay!
Old May 29, 2005 | 08:36 AM
jamgwert's Avatar
Default Re: ECU CODES?? (JDMJNKY)
Buy a code reader.
Old May 29, 2005 | 08:37 AM
Bcuz's Avatar
Under your glove box there is a blue 2 pin connector, run a wire from one side to the other and turn your key to on position and pay attention to your cel light, it will blink. Long blink equals ten, and short blink equals one. Exampl- long, long, short,short, Would be code 22. Keep posting
JDMlyfestyle's Avatar
wow the first thread in this forum
https://honda-tech.com/zerothread?id=1171263
Old May 29, 2005 | 08:38 AM
jamgwert's Avatar
Or if you go to some parts stores they can check it for you.
Old May 29, 2005 | 08:39 AM
jamgwert's Avatar
Default Re: ECU CODES?? (Bcuz)
I was unaware you could do the paper clip trick on an OBD2 motor
Old May 29, 2005 | 08:40 AM
JDMJNKY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz &raquo;</TD></TR><TR><TD CLASS="quote">Under your glove box there is a blue 2 pin connector, run a wire from one side to the other and turn your key to on position and pay attention to your cel light, it will blink. Long blink equals ten, and short blink equals one. Exampl- long, long, short,short, Would be code 22. Keep posting</TD></TR></TABLE>
thanx!! just what I was lookin for!!
Old May 29, 2005 | 08:42 AM
JDMJNKY's Avatar
going outside to check be back in 10!
Old May 29, 2005 | 08:44 AM
Bcuz's Avatar
Default Re: ECU CODES?? (jamgwert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamgwert &raquo;</TD></TR><TR><TD CLASS="quote">I was unaware you could do the paper clip trick on an OBD2 motor
Then maybe you should read more and post less.
Old May 29, 2005 | 08:48 AM
Patron's Avatar
Then maybe you should read more and post less.</TD></TR></TABLE>
He's been on here 2 years. I'm sure he does alot more reading than posting.
Old May 29, 2005 | 08:49 AM
Bcuz's Avatar
Default Re: ECU CODES?? (ptran13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran13 &raquo;</TD></TR><TR><TD CLASS="quote">
He's been on here 2 years. I'm sure he does alot more reading than posting. </TD></TR></TABLE>
Or maybe he doesn't spend his time on this site, like we all do, fcking honda's are so addictive
Old May 29, 2005 | 08:59 AM
jamgwert's Avatar
I didn't know you could get your CEL light to flash P0010 and all those codes for OBD2 motors.
Old May 29, 2005 | 09:00 AM
JDMJNKY's Avatar
ok here's the prob I cant find that small blue plug on the 96 ex, But I know My 99 Si has one b/c I did the ecu check on it before. What do i do or how can I locate that plug??? any pics of its location?????
Old May 29, 2005 | 09:02 AM
Patron's Avatar
Default Re: (JDMJNKY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">ok here's the prob I cant find that small blue plug on the 96 ex, But I know My 99 Si has one b/c I did the ecu check on it before. What do i do or how can I locate that plug??? any pics of its location?????</TD></TR></TABLE>
Same location as your Si. It's probably buried in the dash.
Old May 29, 2005 | 09:05 AM
JDMJNKY's Avatar
Default Re: (ptran13)
Same location as your Si. It's probably buried in the dash. </TD></TR></TABLE>
on the passenger side right???
Old May 29, 2005 | 09:06 AM
Patron's Avatar
on the passenger side right???</TD></TR></TABLE>
You should know, you did it with your Si.
Old May 29, 2005 | 09:10 AM
JDMJNKY's Avatar
^^^lol...smart ***, I thought 96-98 would be diff. from 99-00, guess I was wrong!
JDM PRO's Avatar
i too would like to know where it's located...pix would be great
Old May 29, 2005 | 09:23 AM
JDMJNKY's Avatar
BINGO I FOUND B_B_I 10!!!
Old May 29, 2005 | 09:28 AM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamgwert &raquo;</TD></TR><TR><TD CLASS="quote">I didn't know you could get your CEL light to flash P0010 and all those codes for OBD2 motors.</TD></TR></TABLE>
You only get those codes with a reader. with the paperclip you just CEL flashes.
Old May 29, 2005 | 09:54 AM
JDMJNKY's Avatar
Default HOW TO TURN 10 min. into 60, BY J WEB!!!
LOL.....Being this new car to us, I had just found the alarm remote to the silent alarm...hehe, but the funny parts is that while lookin' for the plug, on the drivers side?? The car keys had fell out my pocket....w/out me knowing. I come inside to let you guys know I found the plug, HOOORAY. So excited I return outside w/ the remote in hand to unlock the doors and get to work. Everythings hooked up time to turn the ignition on **oopsie** I forgot the keys in the house, so I dash inside w/ my one leg, leaving the remote behind. I close the door w/ the alarm remote in the car (seperate from key chain no clip) un-beknown to me the car has automatic locks...humm can't find the keys????? so I frantically begin my search for the keys??? It begins to arise the misses curiousity! so then wifey comes to take a look and notices all our keys are locked in the car...LMFAO:confused: I called AAA and they told me 'they'll send some one out within the hour"....(wipe sweat off forehead)
Old May 29, 2005 | 10:47 AM
JDMJNKY's Avatar
It flashed either an 11/20?? what does that mean where can I get some info. on those codes???
Old May 29, 2005 | 12:39 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">It flashed either an 11/20?? what does that mean where can I get some info. on those codes???</TD></TR></TABLE>
Did it flash one long and one short? Pause and keep repeating?
Old May 29, 2005 | 12:41 PM
Here you go. watch the video and there is a list of codes to check it with.
ECU code thread. its the 1st or 2nd thread on this page.
Old May 29, 2005 | 01:35 PM
JDMJNKY's Avatar
Default Re: (Chiovnidca)
it looked like one long & one short but, by time/ clocking it they both flashed for 2sec, and reapeated???
