what are good cams for F/I??
Old May 29, 2005 | 08:09 AM
99 civic si's Avatar
Default what are good cams for F/I??
i am currently running 65 wet shot, i heard that cams are unneccessary with f/i but i heard agian they are useful. ctr cams is what i am thinkin but i would like to get my red line up higher to possible 9000 maybe close to 10,000. whatever is safe for nitrous.
thank you.
Old May 29, 2005 | 08:15 AM
Archidictus's Avatar
Unceasing Measure
Default Re: what are good cams for F/I?? (99 civic si)
GSR cams are great for turbo and supercharging. Then again, nitrous is a compliment to whatever setup you're running, so if you're otherwise all-motor, you should get some really chunky cams and valvetrain components that can handle it and keep on doing your thing.
By the way: revving higher doesn't gain you anything unless your camshafts make power that high. Wanting more revs is a ricer mentality that gains floating valves, interference and blown motors.
Old May 29, 2005 | 04:51 PM
sTohc99's Avatar
if you wanna get to 10K you better get more than just a cam
Old May 29, 2005 | 09:55 PM
Default Re: what are good cams for F/I?? (sTohc99)
skunk2 stage 2 is what i have been looking at if possible that is new cams, valves, retainers, springs etc.
Old May 30, 2005 | 12:03 AM
808_si's Avatar
Default Re: what are good cams for F/I?? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">GSR cams are great for turbo and supercharging. Then again, nitrous is a compliment to whatever setup you're running, so if you're otherwise all-motor, you should get some really chunky cams and valvetrain components that can handle it and keep on doing your thing.
By the way: revving higher doesn't gain you anything unless your camshafts make power that high. Wanting more revs is a ricer mentality that gains floating valves, interference and blown motors.</TD></TR></TABLE>
werd
swpdb16
Apr 3, 2004 12:08 PM
bottlefedb18c1
Jun 9, 2003 06:56 PM
fastludeh22
Aug 2, 2002 06:25 AM
fastludeh22
Aug 1, 2002 10:35 AM
