Clutch Hesitates to Come up in 1st
Old Feb 7, 2002 | 01:33 PM
MacLeanQuinn's Avatar
New User
Default Clutch Hesitates to Come up in 1st
Hey guys,
Sometimes, not everytime by any means, but with more and more frequency my clutch hesitates to come up from the floor when I am going from a stop. The clutch almost feels like it is stuck and then starts coming up. I have checked and there is nothing physically causing this (ie. floormat or something under the pedal), and ideas what it could be? The car is a 2001 gs-r with 15,000 miles on it.
Thanks a lot
McLean
Old Feb 7, 2002 | 01:36 PM
Batoutahell's Avatar
Default Re: Clutch Hesitates to Come up in 1st (MacLeanQuinn)
An easy thing to check is your clutch fluid level. You can also bleed the line fairly easily if necessary.
Old Feb 7, 2002 | 02:43 PM
NighthawkR184's Avatar
It sounds like you have a leak in the system. Usually when you bleed the system the pedal stick to the floor and you have to pull the pedal up. You need to check the fluid level then for leaks. Look at the slave cylinder and on the inside of the fire wall at the top of the clutch pedal.
david236kEG
23
Jan 28, 2009 03:34 PM
Gomdohree
Apr 24, 2008 06:20 AM
Lb1atx
Sep 7, 2007 05:16 AM
SPOOLINmatt
Mar 14, 2005 01:04 PM
Superdragr45
Jan 26, 2004 08:17 PM
