Turbo Rebuild Complete Torque Specs Here!
Old May 29, 2005 | 03:48 AM
Cloner's Avatar
Default Turbo Rebuild Complete Torque Specs Here!
Just posting this because I searched here for a turbo rebuild write up and couldnt find anything in the past.I'll do a write up with pictures,diagrams,specs.My digital camera is broken so thats why Im not doing it yet.
Turbo-to Turbo manifold bolt: 40-47 ftlbs
Torque the compressor nut to 18-20 in-lb (that's INCH-pounds NOT foot-pounds)(1.5-1.6 ftlbs) Then continue to rotate the nut an ADDITIONAL 90 to 110 degrees. DO NOT use any sealers on the nut or shaft threads--the nut is self locking.
Tighten compressor housing to 145-165 in./lbs (12-14 ftlbs)
Turbine housing to 185-200 in./lbs.(15-17 ftlbs) Make sure turbine wheel does not contact the housing in any position.
Backplate 8 ft-lbs ( Correct me if Im wrong found two different torque specs on this.)
Oil drain flange 34ft-lbs
Oil inlet flange 38ft-lbs
Downpipe flange to turbo exhaust housing Torque to 32-40 ft-lbs
Old May 29, 2005 | 12:08 PM
Cloner's Avatar
Default Re: Turbo Rebuild Complete Torque Specs Here! (Cloner)
If anyone else has any torque specs on the backplate please post.
Old Sep 19, 2007 | 03:19 PM
Muckman's Avatar
Moderator in Chief
This is a great thread thank you.
Old Sep 19, 2007 | 03:50 PM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cloner &raquo;</TD></TR><TR><TD CLASS="quote">If anyone else has any torque specs on the backplate please post.</TD></TR></TABLE>
GT Series - Snap Ring ftw
Old Sep 19, 2007 | 04:29 PM
tony1's Avatar
Default Re: Turbo Rebuild Complete Torque Specs Here! (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">This is a great thread thank you. </TD></TR></TABLE>
Except that torque ratings are dependant upon fasteners used, and there's all kinds of different fasteners used on turbos. Those specs might be right for 1 turbo, but there is no universal spec...
Old Sep 19, 2007 | 05:18 PM
Muckman's Avatar
Moderator in Chief
Default Re: Turbo Rebuild Complete Torque Specs Here! (tony1)
Hey its better than nothing. You know how many threads there are about this subject with no real technical answer? #1 most common response "make it snug"...
Old Sep 20, 2007 | 05:51 AM
tony1's Avatar
No information is better than bad information...
"make it snug" makes sense to a mechanic, and if you tell somebody that and they strip a bolt, it's their fault. You tell someone an incorrect torque spec and they strip a bolt, they're pointing fingers at you.
I have NEVER torqued the bolts holding a turbo together, 90% of the time you couldn't even if you wanted to.
Old Sep 20, 2007 | 07:04 AM
Yep... good luck fitting a torque wrench in there.
Old Sep 20, 2007 | 08:16 AM
IntegraTypeR's Avatar
Default Re: Turbo Rebuild Complete Torque Specs Here! (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Yep... good luck fitting a torque wrench in there.</TD></TR></TABLE>
well most small torque wrenches that do in/lbs should fit there! am talking about the ones that torque a MAX of 12-14ft/lbs
well myself i didnt torque any bolts around the turbo just tighten until they are snug, but i have this small torque wrench which i really find useful for torqing small bolts in tight area!
to get an idea what am talking about i got this one:
http://www.handsontools.com/st....html
Old Sep 20, 2007 | 09:17 AM
Default Re: Turbo Rebuild Complete Torque Specs Here! (IntegraTypeR)
I know which wrench you are speaking of. I think what tony is trying to imply is when the turbo is clocked there are a few bolts that you can barely even tighten with an open-ended wrench less alone fitting a torque wrench in there.
What you could use is a crow-foot socket:
Dunc
Jun 22, 2011 10:35 AM
cilvia
Jul 30, 2010 03:45 PM
Dunc
May 23, 2006 12:20 PM
Clone
Nov 7, 2004 05:57 AM
