what damage will a piece of rubber glove do to my new motor...?
i barely put about 300 miles on my new motor and i put a shitty intake for now... and on vaccum and other small entrances i capped it off with tips of rubber glove... very stupid idea... and after driving for a while it actually sucked it a small piece... about .75 diameter... do you guys think it will cause a serious damage to my motor...? motor sounds ok... i think... just light noises its coming from the motor.... thanks for any advices in advance... have a great holiday~
let me get this straight...
you put pieces of a rubber glove on the holes on your intake...on a NEW motor.
you might have a problem, you might not, depends on how far that **** got sucked in.
take your intake and throttle body off and look into your intake manifold and see if you can find it in there.
if you are lucky it sucked it in and spit it out. i had a $25,000 chevy motor suck in some rags
, luckily it burned them up and spit em out with no damage.
I would still take the intake off and see if you can find it.
good luck
, luckily it burned them up and spit em out with no damage. I would still take the intake off and see if you can find it.
good luck
Little rubber pieces from a glove? It won't do anything. It'll just melt off inside the combustion chamber.
The noises you're hearing is probably just in your head. It was probably the same before the glove incident too.
thats what i was thinking...
noise in my head...lol thanks guys and i will go ahead and check out the intake manifold
