Problems shifting from 4th to 5th... then a KAA-CHUKKK on freeway....
Old May 28, 2005 | 11:21 PM
Leithen's Avatar
Default Problems shifting from 4th to 5th... then a KAA-CHUKKK on freeway....
So I noticed this morning when I was driving to work i was having problems shifting from 4th gear to 5th. Sometimes it worked....as if I was shifting without using the cluth....
So I decided I was going to take it in on tuesday...so i was driving carefully back home after work, on the freeway, and i was shifting from 4th to 5th and heard a big KACHUKK, and lost all ability to shift into any gear and the clutch went gummy.
I pulled over to the side of the road, and checked under the hood, and found nothing, no liquid under the car, so i decided to try to start it up. I put the car in neutral start up the engine, and let it idle....it idled fine.
turned off car.
when car was off, I shifted into first gear, and started up the car...it immediately jumped forward and started going, but if i ever shifted out of first, the clutch would not engage again.
whats the problem?
is it the disk?
was there a leak in the transmission fluid?
its parked outside an acura repair shop, but I dunno what to do?
HELPP!!!!
Old May 29, 2005 | 02:44 AM
yrethguad's Avatar
Default Re: Problems shifting from 4th to 5th... then a KAA-CHUKKK on freeway.... (Leithen)
Need new clutch. There's a bunch of threads on this, check it out.
The clutch spring comes out, and causes problems just like what you're having.
Old May 29, 2005 | 04:13 AM
[ iLL ] iNt3GrA's Avatar
yep happend to me! time to drop the trans have fun
Old May 29, 2005 | 05:21 AM
Racermech's Avatar
Default Re: ([ iLL ] iNt3GrA)
Tow that aways from the dealer. They will want close to $1000 for a clutch swap. Any general mechanic can put a clutch in for half that
Old May 29, 2005 | 06:52 AM
maxogsr's Avatar
Default Re: (Racermech)
It also happen to me...Had to shift it without the clutch to the garage...
If you got acces to a clutch manufaturer near your place then get a double pp and stage 2 clutch and it should solve the prob for a while...The pedal will be a bit firmer but it's a lot stronger... If you want names (Centerforce, etc...) you'll pay the big prices...
**** happen!
Old May 29, 2005 | 07:00 AM
LSracing94's Avatar
Default Re: (maxogsr)
get an ACT extreme pressure plate w/ street strip disc
bseries_beast
Jun 6, 2005 09:33 PM
AgentUT
Apr 18, 2004 06:39 PM
KooK
Honda S2000
Nov 18, 2003 07:42 AM
missinghubcabs
Jun 25, 2003 03:41 PM
