Has anyone stuffed a 16x8 +43 on an R yet?
Old May 28, 2005 | 06:38 PM
yellow blur's Avatar
Default Has anyone stuffed a 16x8 +43 on an R yet?
Just as topic says, anyone fit a 16x8 on their car yet? +43 off set. Did you do it using a 40/45/50 sidewall?
Ed
Old May 28, 2005 | 09:11 PM
Black R's Avatar
25 Year Member
Default Re: Has anyone stuffed a 16x8 +43 on an R yet? (yellow blur)
.....I've used fd3s wheels in 16x8 +50 offset.
You need a spacer to clear and 215's are ideal... Although more spacers would give more room on the inside - it's the rear trailing arm that has clearance issues with wider tires.
I'd go with a +35 offset if I had a choice, although closer to +25 would be ideal (imho).
Old May 28, 2005 | 09:17 PM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">Just as topic says, anyone fit a 16x8 on their car yet? +43 off set. Did you do it using a 40/45/50 sidewall?
Ed</TD></TR></TABLE>
Yasu's ITR uses 16x8 CE28s up front but I have no idea what wheel offsets or size tires he uses. No specifics on the site.
Modified by ITRbroham at 5:40 AM 5/29/2005
Old May 29, 2005 | 01:41 AM
ITR3189's Avatar
Default Re: Has anyone stuffed a 16x8 +43 on an R yet? (ITRbroham)
Where can I find more pics of Yasu´s car ?
Old May 29, 2005 | 03:38 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">Just as topic says, anyone fit a 16x8 on their car yet? +43 off set. Did you do it using a 40/45/50 sidewall? </TD></TR></TABLE>
See if you can PM Todd00. He had 8" wheels on his ITR, but I'm not sure what offset or what tyres.
Old May 29, 2005 | 04:49 AM
ITRbroham's Avatar
shit post warrior
Default Re: Has anyone stuffed a 16x8 +43 on an R yet? (ITR3189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR3189 &raquo;</TD></TR><TR><TD CLASS="quote">Where can I find more pics of Yasu´s car ?</TD></TR></TABLE>
http://www.a-t-s-usa.com
Old May 29, 2005 | 11:13 AM
NTGR8D's Avatar
Yasu's using fender flares though, so that might not help you guys..
Old May 29, 2005 | 11:12 PM
Default Re: Has anyone stuffed a 16x8 +43 on an R yet? (NTGR8D)
Thanks for the info guys. Yeah the ATS/J's car has J's fender flares, I'm not sure if I want to get that radical with the fenders.
I'll do some more checking and post what I can find.
Old May 30, 2005 | 01:02 AM
Ajax's Avatar
What a ricer, look at the size of that wing
Old May 30, 2005 | 09:47 AM
Todd00's Avatar
I said I don't want a title!
16x8 +38 fits fine with 215/45/16 Azenis all the way around. Fenders need to be rolled, but nothing extreme.
Old May 30, 2005 | 11:11 AM
Default Re: Has anyone stuffed a 16x8 +43 on an R yet? (Todd00)
Then +43 should be fine, probably no fender rolling required right?
Old May 30, 2005 | 12:32 PM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">Then +43 should be fine, probably no fender rolling required right?</TD></TR></TABLE>
Then it probably would depend on the size tire, sidewall height, and how much your ITR is lowered.
Old May 30, 2005 | 12:38 PM
Stock suspension with a 205/55, that's what they come with. I probably will be changing tire sizes later.
Old Jul 2, 2005 | 04:44 PM
98SpecR's Avatar
what's up bro? your fender might be alright, but you may have trouble with turning. the tire will rub.
Old Jul 2, 2005 | 07:13 PM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info guys. Yeah the ATS/J's car has J's fender flares, I'm not sure if I want to get that radical with the fenders.
I'll do some more checking and post what I can find.</TD></TR></TABLE>
You know, they are only $220 from http://www.aj-racing.com
Old Jul 2, 2005 | 09:17 PM
migs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">Stock suspension with a 205/55, that's what they come with. I probably will be changing tire sizes later.</TD></TR></TABLE>
205-55-16
Holy crap dude. Lose those tires quick!
Old Jul 2, 2005 | 10:21 PM
Pondus's Avatar
Default Re: Has anyone stuffed a 16x8 +43 on an R yet? (migs)
Yeah, I'm using 205/50-16 and no way will 205/55-16 be working out, maybe if you jack it up 4x4 style
Old Jul 2, 2005 | 11:49 PM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">16x8 +38 fits fine with 215/45/16 Azenis all the way around. Fenders need to be rolled, but nothing extreme.</TD></TR></TABLE>
So then maybe 16x8.5 +37 with 225/45-16 will fit as well?. Only gonna be used up front, and will gladly roll fenders to make it work. Was just looking at the Buddy Club P1 racing wheels and they are available in that size with a 5x114.3 lug pattern, and is not too expensive either.
Old Jul 3, 2005 | 12:26 AM
Default Re: Has anyone stuffed a 16x8 +43 on an R yet? (Pondus)
I ended up going with not a 16x8 but a staggered 16x7 and 15x6.5 for the rear. I don't really need to worry about the 8" width anymore.
aznbigman
May 1, 2008 11:14 PM
crr
Apr 14, 2007 10:16 AM
HeavyFoot_Tony
Honda S2000
Dec 3, 2005 07:38 PM
FrostyDC4
Oct 1, 2004 05:40 PM
GroundZer0 336
Nov 11, 2003 11:25 AM
