wiring into ecu harness
Old May 28, 2005 | 06:25 PM
Monkey Fing a Coconut's Avatar
Default wiring into ecu harness
could anybody post up how or link to the correct way to run a wire into the ecu harness, im trying to wire up the iab and not quite sure how to secure the wire into the harness plug
thanks
Old May 28, 2005 | 06:58 PM
scrubachu's Avatar
Default Re: wiring into ecu harness (twistedbydezign)
run the wire, either 8-10 guage to the ecu, and strip about 1 1/2 inch off the cover of the wire at the end by the ecu. youll want to then trim some of the excess wire because itll be too thick. twist the remaining wire up and then find the plug and slot where the pin out is and slide the wire all the way through the ecu plug on the harness. meaning silde the wire the same direction the other wires are coming form the harness until it goes all the way through, and bend the leftover wire against the plug and plug it into the ecu. itll still plug just fine. i have my vtec wires and knock sensor wire done like that for over 3 years now, and never a problem.
clockstick
Oct 27, 2009 06:54 PM
Dead CIVIC
Jan 28, 2008 03:40 PM
9281hatch
Sep 11, 2006 12:18 PM
