cf hood clearance
i don't want to cut my stock hood so wich carbon fiber one can i use? i have a b16 with az race machine mounts. i have herad that the zc works but will the invader or the oemfrom vis thanks a lot in advance
what do you mean my stock hood won't close or do you mean any of the carbon fiber ones will work becuase i want the invader but i wasn't sure if that scoop would dip down where i need the clearance
by jdm style i mean i mean something like this. i believe vis makes something like the jdm style hood but in cf. i've seen it before...
This is my crx and i have a b16a i have no issues about the head hitting the hood or anything...
in other words, the jdm sir style has the center of the hood raised up a tad rather than the center sinking in like our usdm hoods. and the only b series you should have a problem with hood clearance would be the gsr or type r motors. have a front strut brace or aftermarket intake that could be sitting too high? if all else fails, slam the sucka! lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 »</TD></TR><TR><TD CLASS="quote">You either timed that picture just right, or you hooked up the turn signals as running lights.</TD></TR></TABLE>
you can do long shuttr speed also
FYI, the bump in the VIS ZC style hood is cosmetic only. the fiberglass skeleton is the same one they use for the OEM USDM hood. so if you're looking for more clearance, get the SiR Style for USDM front ends.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si »</TD></TR><TR><TD CLASS="quote">are ya talking about my cornerlights? </TD></TR></TABLE>
Yes,... the wrap arounds and side blinkers....how are they hooked up?
I did the same thing with my lights on my sir conversion, i took a spare dual filament socket from a taillight and modified it to fit the lenses, and just ran the extra wire(for parking lights) to the corner lights
Yes,... the wrap arounds and side blinkers....how are they hooked up?</TD></TR></TABLE>
i hooked em up with the trun signals
JDM_ITR
May 2, 2002 05:09 PM
