Cutting Carbon Fiber Question
Old May 28, 2005 | 03:24 PM
civicshowracing65's Avatar
Default Cutting Carbon Fiber Question
hey guys i had a question in regards to cutting carbon fiber with a dremel. After making my cf piece with 2 layers of resin i got my dremel and started to cut the shape of the piece i wanted. The only problem is that when all that powder dust thing gets on the top of the nice clear resin layer it makes it all hazy. How do you prevent that because without the nice clearness, cf is worthless for show pieces. I tried taping the top side but it left sticky crap from the tape.
Before i start cutting am i suppose to spray a uv clear coat first?
Old May 28, 2005 | 03:28 PM
ExploitedRacing-HR's Avatar
wash it in water to get the powder crap out... or spray it off with compressed air....
Im not exaclty a carbonfiber expert but i dont think a little water would hurt it after its already hard.
Old May 28, 2005 | 04:01 PM
funvtec's Avatar
Default Re: (ExploitedRacing)
use a painters tape
Old May 28, 2005 | 05:44 PM
Default Re: Cutting Carbon Fiber Question (civicshowracing65)
water doesn't help. tried that. Tried using rubbing alcohol and mx7 too
Old May 29, 2005 | 02:35 AM
mh's Avatar
mh
if it's only 2 layers of fiber, you can us a knife to cut it. worked for me, but it cant be too thick.
Old May 29, 2005 | 04:59 AM
neogenesis2004's Avatar
Default Re: Cutting Carbon Fiber Question (mh)
1)lay cloth
2)pour resin, minor tweaking and allow to dry. Vacuum bag if possible
3)trim using tape along edges to help keep straight cuts and minimize fraying of edges
4)Wet sand
5)Gel coat
6)wetsand
7)UV clearcoat if desired
8)wetsand
9)buff
I think you can see where and blemishes are removed in the above steps
Greyout
Welding / Fabrication
14
Aug 12, 2012 08:55 AM
SLIM NOTHING
Jan 29, 2011 02:48 PM
i drive a honda
12
Oct 29, 2008 03:44 PM
datssoled
Feb 17, 2007 06:43 PM
Bloodline
Sep 23, 2004 09:29 AM
