HOW can i know if i need a FPR ??
hello everybody
as topic says.
here is my setup....
97 civic 1.4is (D14A4).
Tunertoys log manifold. (blocked WG flange)
garrett T3 .48/.67 internal wastegate.
GREEDY BLUEBOX.
SMIC.
2" chargepipes from the turbo to the intercooler.
2.5" chargepipes from intercooler to the TB.
hks super BOV.
Fasturbo oil lines.
2" DownPipe
diy catch can.
thanx.
as topic says.
GREEDY BLUEBOX.
SMIC.
hks super BOV.
Fasturbo oil lines.
2" DownPipe
diy catch can.
thanx.
Guest
Posts: n/a
the only reason you will need a FPR is if your injector sizing is too big or too small for your power goals. if they are too small you can turn up the pressure to compensate, but you will want a higher flowing fuel pump to compensate. if they are too big, you may want to durn the pressure down a bit for idle.
null.
Aug 7, 2004 08:48 AM
