B18B1 question? (confused)
Old May 28, 2005 | 01:20 PM
som1_2race's Avatar
Default B18B1 question? (confused)
If the B18B1 was introduced between 92-95. Why are there 3 ecu's for it the PR4 & P74/75 if there both OBD-1? Is there a OBD-0 ecu for this engine?
Old May 28, 2005 | 01:32 PM
brickonwheels's Avatar
the b18b was produced through the end of the integra run. the pr4 is from the b18a, and the p75 is the obdI from 94 and 95.
Old May 28, 2005 | 01:48 PM
som1_2race's Avatar
so I assume the PR4 is OBD-0? correct.
Old May 29, 2005 | 07:18 AM
I believe so, maybe wrong though
Old May 29, 2005 | 09:00 AM
projectTeG's Avatar
the b18b was introduced in 94 until the end of the gen 3 integras and the pr4 is the Da ecu
Old May 29, 2005 | 09:04 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: (projectTeG)
well 92-93 b18a's are obd1, so im guessing you can use an ecu from a 92-93 integra on a 94-95 LS.
Old May 29, 2005 | 10:58 AM
JDMdreamer
Guest
Posts: n/a
Default Re: (benb18a)
90-91 was obd0 and 92-93 was obd1 and 90-93 used the b18A1 as for the ECU's, PR4 is the obd1 ecu for the 92-93...i dont know the obd0 ecu though
Old May 29, 2005 | 03:04 PM
sexyblack93lude's Avatar
there are both obd o pr4's and obd 1 pr4's
Old May 29, 2005 | 04:39 PM
Launchpad's Avatar
Default Re: (sexyblack93lude)
Is there any difference in the map on a pr4 and a p74?
Old May 29, 2005 | 07:38 PM
som1_2race's Avatar
I figure there were both OBD-0 & 1. For now my cuz is wiring up the B18B1 to his PR4 in the EF.
Old May 29, 2005 | 08:24 PM
jdmsijdm's Avatar
i heard that if you use a b18b1 and an 90-91 ecu or 92-93 ecu you will burn up the b18b1 injectors because of a resistor box or something? is this true?
Old May 30, 2005 | 01:13 PM
som1_2race's Avatar
btt
Old May 30, 2005 | 05:13 PM
urb's Avatar
urb
Default Re: (som1_2race)
Just do a head swap,b18b head to a b18a bottom.You shouldnt run into any problems this way.But well im not sure as to what you are trying to do??
88CReXin
May 24, 2007 11:45 AM
egboostin6
Apr 19, 2007 08:36 PM
b18delturbo
Nov 2, 2005 08:22 AM
JCracer723
Dec 1, 2003 12:12 PM
