88 Accord Clutch problems
Old May 28, 2005 | 12:49 PM
toasterxb's Avatar
Default 88 Accord Clutch problems
I am helping a friend troubleshoot his issue, and he has an 88 Accord and what is happening is the clutch pedal can be pushed in but won't spring back. He has to pick it up off the floor with his foot. He seems to think it is the pressure plate, i think it could just be a bad clutch cable/connection somewhere. Just wanted some other opinions on what it could be.
Thanks alot.
Old May 28, 2005 | 12:59 PM
EX_VTEC's Avatar
Swap a new h22
and you forgate the problems
Old May 28, 2005 | 01:02 PM
Chiovnidca's Avatar
Default Re: 88 Accord Clutch problems (toasterxb)
Does the clutch cable move the release arm? Is the cable properly adjusted?
Old May 28, 2005 | 01:05 PM
toasterxb's Avatar
Default Re: (EX_VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Swap a new h22
and you forgate the problems</TD></TR></TABLE>
Wish i could but it isn't my car and this is his beater.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Does the clutch cable move the release arm? Is the cable properly adjusted?</TD></TR></TABLE>
Yes the clutch cable moves the release arm, and the cable odes not have excessive slack or overtightened.
Nice thinking though, i thought the same thing
Old May 28, 2005 | 01:24 PM
Chiovnidca's Avatar
Default Re: (toasterxb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toasterxb &raquo;</TD></TR><TR><TD CLASS="quote">
Nice thinking though, i thought the same thing</TD></TR></TABLE>
What does that leave then?
Old May 28, 2005 | 01:52 PM
toasterxb's Avatar
Default Re: (Chiovnidca)
What does that leave then?</TD></TR></TABLE>
Pressure plate and or the whole clutch assembly i am guessing. I really don't think he wants to drop that much money into it.
Is it possible to have the clutch cable fall off/ come off the pedal assembly? I am not current'y at the car abnd i am just telling you guys what he tells me, i am sure when i get there tonight it will be somethign small like the cable.
Old May 28, 2005 | 02:02 PM
Chiovnidca's Avatar
Is it possible to have the clutch cable fall off/ come off the pedal assembly? </TD></TR></TABLE>
It's not very likely it would just fall off, it could break. But with either one of those scenarios, would the release arm move?
Old May 28, 2005 | 02:03 PM
toasterxb's Avatar
you are correct, didn't think abo it like that.
So what could it be then? Just the whole clutch assembly?
Old May 28, 2005 | 06:51 PM
deserthonda's Avatar
when he brings the pedal back up by hand does it feel normal when the clutch pedal is depressed??? i would look under the dash by clutch pedal maybe the return spring came unhooked or broken
Old May 28, 2005 | 08:14 PM
Vanilla Sky's Avatar
my guess is also the return spring
baboracus
Sep 4, 2007 08:09 PM
I Like Hondas
Mar 16, 2006 02:40 PM
PIC Performance
Mar 26, 2005 02:54 PM
asmallsol
Aug 9, 2004 08:06 AM
Steve90HB
Feb 14, 2004 07:38 AM
