H23 vtec swap, tach not working. PLEASE HELP por favor.
i have a VTEC swapped 94 lude SI. After i did the swap, my tach does not work at all. Any help would be great. Thanks.
PS. i tried searching.
did you change anything on the gauge cluster? if the car runs then that means the ecu has a tach signal if thats the case you have a wire lose somewhere near the gauge, or you could have a lose wire coming fromt he distributor,
did u change the ecu , engine wiring harness? my guess is you cut or upluged something when runing wires or moving everything around.
acaliguy
Feb 4, 2013 08:53 PM
