Need help !!!!!
Old May 28, 2005 | 12:23 PM
P2R4DREF's Avatar
Default Need help !!!!!
First the story. Have 4dr ef got the car with single cam vtec car was rigged up to obd 1. Put B16 in her she ran but it did not run right. So decided to go back to none obd. got engine harness converted it got resister box and injectors. I know every thing is correct I checked and double checked every thing but car wont run. It starts but it sounds like its only running on one leg and then it cuts out . The only code I get is 10. Im running a ls stick computer I know it works it started my boys B. Thought it was the harness so I went and got my year and make harness and did it again but still nothing. I am burnt out so any ideas would help. Thanks in advance .
Old May 28, 2005 | 12:31 PM
d16efsedan's Avatar
Default Re: Need help !!!!! (P2R4DREF)
is this the automatic car you was talking about?could be that you have a manual ecu.other than that i wouldnt know,im not a b-series guy....
Old May 28, 2005 | 12:33 PM
P2R4DREF's Avatar
The car is manual.
Old May 28, 2005 | 01:25 PM
neutron91's Avatar
Default Re: (P2R4DREF)
have you checked your firing order?
Old May 29, 2005 | 12:41 PM
P2R4DREF's Avatar
yes its fine im geting fuel and spark but it just aint happening.
streetracer4lif
Jun 27, 2016 07:54 PM
dragon909boi
Jul 9, 2015 08:42 PM
hondABcrx_
Jan 28, 2015 06:14 AM
dusterbd13
Oct 4, 2009 11:32 AM
