89 CRX Cluster in a 90 CRX.
Old May 28, 2005 | 11:55 AM
Bright Eyes's Avatar
Default 89 CRX Cluster in a 90 CRX.
I just did a full interior swap in my 90 CRX. problem is my parts car is an 89, so the cluster/cluster cover and mount point for the cluster aren't the same.
The 89 and 90 clusters have the same exact 3 plugs, and they all fit, but will the cluster work? I'm in the process of swapping the motor so I haven't gotten a chance to check. Thanks!
Old May 28, 2005 | 03:05 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: 89 CRX Cluster in a 90 CRX. (Eileen)
Asimple search will give you the info you need, the wire colors are the same, you just need to switch the pins around
Old May 28, 2005 | 04:01 PM
thrill_house's Avatar
I have done the 88 cluster in my 91 and IMO your allot better off just getting a 90 or 91 cluster for the car.
Old May 28, 2005 | 05:26 PM
Thanks guys I guess I will swap the stock cluster back in and figure out a way to mount everything
k-on-spray
Oct 30, 2011 05:46 PM
pnk_03
Jan 9, 2008 07:54 AM
AndrePerras
Dec 3, 2006 06:16 PM
stevescivic
Feb 27, 2005 09:55 AM
Vaans
Aug 2, 2004 01:24 PM
