B18c1 Swap into a del sol?
Well i am going to to alot of things to my del sol. currently have a d16z6 in it and i was thinking about putting a b16a2 but i think im gonna go with the b18c1. what do i need to do the del sol so it will fit like suspension,mounts etc.
Thanks
Thanks
Not trying to be a H-T ******* but you should roll thru this thread https://honda-tech.com/zerothread?id=878010
EDIT: Suspension will be fine...unless you feel like improving it. Motor mounts I'm not to sure on....if its anything like the civic's then you'll need/want an aftermarket mount kit or you can use (I believe) 99-00 civic Si mounts on certain uh...mounts.
If you can, purchase a complete swap, or else you will have to get a list of what that consists of and go shopping around! Pack up that list and you're good to go...
Just a couple random things off the top of my head...
B series mounts, axles, you basically need everything B series...
1993DelSolSI
43
Jan 6, 2011 07:30 PM
90civichb
Jun 5, 2004 04:13 AM
