valve tapping..
Old May 28, 2005 | 08:06 AM
honda011's Avatar
Default valve tapping..
hey honda-tech, i got vavle tapping, how can i get rid of this????? and is it doing alot of harm??
Old May 28, 2005 | 08:53 AM
urb's Avatar
urb
Default Re: valve tapping.. (honda011)
Most likely you are in need of a valve lash adjustment.To find a pretty reliable source for doing this yourself,which its not hard if you have a pretty good feel for mechanics.Check autozone .com and go to repair info.Or get a chilton or a haynes repair manual.Or hit me up and ill give you step by step info.But your gonna need to know what the specs are for your vehicle first.Specs i mean amount of clearance needed between your cam lobe and your rocker arm.
Old May 28, 2005 | 09:17 AM
ALMXDUPINTEGRA's Avatar
^^Good advice
Moogen Powah's Avatar
Default Re: valve tapping.. (urb)
This thread has a few links to instructions on a valve adjustment: https://honda-tech.com/zerothread?id=303365
Old May 28, 2005 | 06:57 PM
honda011's Avatar
Default Re: valve tapping.. (Moogen Powah)
thanks for the help guys...
ml89
Dec 29, 2007 09:56 PM
eliasromero
Mar 12, 2007 08:37 PM
TurBoTeG
Jan 8, 2004 01:54 PM
SuperMan19
Nov 29, 2001 07:55 AM
