d15b or ZC into 1990 civic h/b?
Old May 28, 2005 | 07:33 AM
Jesterian's Avatar
Default d15b or ZC into 1990 civic h/b?
Which swap would be easier/cheaper to drop into my 1990 civic h/b (base model, 4 speed)? a d15b or a ZC?
Old May 28, 2005 | 08:37 AM
EF_9's Avatar
a zc would be easier for you to swap in
Old May 28, 2005 | 08:38 AM
EF_9's Avatar
oh and cheaper not to mention
Old May 28, 2005 | 09:21 AM
Jesterian's Avatar
Default Re: (EF_9)
What would I need to swap the ZC into my car? IE. Wiring changes, axles, etc. What if I get the odb0 version of the engine? That would mean I wouldn't need to upgrade to obd1, correct? Beyond that, is there anything I need to get?
Modified by Jesterian at 10:45 AM 5/28/2005
Old May 28, 2005 | 10:10 AM
Mach69's Avatar
Default Re: (Jesterian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian &raquo;</TD></TR><TR><TD CLASS="quote">What would I need to swap the ZC into my car? IE. Wiring changes, axles, etc. What if I get the odb0 version of the engine? That would mean I wouldn't need to upgrade to obd1, correct? Beyond that, is there anything I need to get?</TD></TR></TABLE>
I am assuming you mean the jdm d15b vtec engine.
First off, you need to specify which ZC, DOHC? SOHC? I know there is debate whether there is a vtec zc, not sure if there is or not, I am confused about that issue. Out of ALL the ZC engines and the d15b, I would take the DOHC ZC engine, and boost it. If you aren't considering the DOHC ZC, then I would go for the jdm d15b, vtec is fun when it kicks in. I also know the SOHC ZC is the same as the d16a6, except it has a hotter cam.
Regardless of what motor you get. I would get a '90-'91 Civic/Crx Si transmission.
Old May 28, 2005 | 10:21 AM
d16efsedan's Avatar
Default Re: (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">
Regardless of what motor you get. I would get a '90-'91 Civic/Crx Si transmission. </TD></TR></TABLE> not to threadjack,but what is the differance between 88-89 and 90-91 si trannys?
Old May 28, 2005 | 10:56 AM
Jesterian's Avatar
Default Re: (d16efhatch)
The DOHC ZC was the one I was talking about.. If I'm not planning on boosting, is the d15b a better choice? How much harder is that install?
Old May 28, 2005 | 11:21 AM
d16efsedan's Avatar
i think the dohc zc will be easier with wiring and everything,d15b vtec you should go obd1 for vtec..imo i think you should go with the zc....
Old May 28, 2005 | 11:56 AM
jdm Ef-9's Avatar
if you do the zc swap. remember that you need to notch out a hole for your altnator.......they stick out a little futher to the right on dohc motor
Old May 30, 2005 | 06:27 AM
Jesterian's Avatar
When I install my ZC tranny, will I need "to get an extension shaft and 88-89 integra axles to use this transmission in your civic" as the auction I'm getting it from says?
Old May 30, 2005 | 07:29 AM
egCoupe's Avatar
Default Re: d15b or ZC into 1990 civic h/b? (Jesterian)
LIsten here i got a friend thats got a JDM D15B vtec single cam that is pretty fin quick hes got it in the same car as u and the swap was pretty easy and the wiring is slightly difficult if ur converting from dual point to multi point no matter what swap u do. So from experience i would say the D15B because no matter what u do to it its still a single cam and that makes it more of a sleeper. ZZZZZZZZ
Old May 30, 2005 | 08:08 AM
Jesterian's Avatar
Come on, need a reply to that tranny question. Do I need to get an extension shaft for it and 88-89 integra axles?
Old May 30, 2005 | 08:38 AM
EF4lyfe's Avatar
i have a d15b vtec jdm in my 90 si hatch, and it moves pretty quick for what it is. I would say go with the d15b, i shouldnt even have to say why, at least the d15b is pretty much the same as the rest of the d-series so parts will be much easier to get, thats what made my decision.
Old Jun 1, 2005 | 08:09 AM
egCoupe's Avatar
Hey i just found out yesterday from a local shop that knows there **** that the Si Tranny is better because it has better gearing. My guy wit the D15B hatch baught one yasterday after he found out hes probably putting a LSD in it before it goes in so itll be better no matter what.
Hope that helps.
Old Jun 16, 2005 | 10:06 PM
z0iid's Avatar
Default Re: (egCoupe)
si tranny has shorter gearing....dx tranny has a longer 5th gear (for gas saver) - you never hit 5th on the drags....so it really doesn't matter
Old Jun 17, 2005 | 10:27 PM
leanback's Avatar
88-89 have 200mm shaft and 90-91 have 212 know this because i had bought a centerforce for a 91 because thats what the catalog showed and of course it was the wrong one
93accordsleeper
Sep 27, 2006 09:03 AM
Project91Hatch
18
Feb 20, 2006 06:27 AM
90b20b4
Jun 27, 2005 02:43 PM
PsychO
Dec 12, 2002 03:55 PM
