JB Weld on Tranny?
Old May 28, 2005 | 01:55 AM
B bOy CrAyOn's Avatar
Default JB Weld on Tranny?
So today i was changing the fluid on my b16 tranny... long story short when i was tightening everything back up i wasnt paying attention and tightened the overfill bolt too much on my tranny and it cracked the tranny case....its not that bad , its about half an inch long... and i cant even fit my nail in the crack but it none the less lets oil seep out and drip....i dont know how to weld and i dont wanna have to go pay for a job to weld this if i can do it myself...i was told to just clean the surface and use JB Weld on it.. and just rub it in and smooth it out... will this stuff really work and how easy is it to do? never done it so any info would be much help.. oh and for information the tranny is made of aluminum so will thats stuff work? whats ur input?
Old May 28, 2005 | 05:13 AM
BouncinOffTheRevLimiter's Avatar
Default Re: JB Weld on Tranny? (B bOy CrAyOn)
I'd say for the price of JB weld that its worth a shot. If it doesn't work, then go spend some real money to fix it..I wish I could JB weld my tranny back together but I don't think JB weld will work with a blown up differential.
Old May 28, 2005 | 05:16 AM
Flashmn's Avatar
Default Re: JB Weld on Tranny? (BouncinOffTheRevLimiter)
I have a feeling JBweld wont work. I personally wouldnt use it.
Old May 28, 2005 | 10:40 AM
hm...i guess its worth a shot...ill try it and if it dont work ill take it to a shop
Old May 28, 2005 | 12:01 PM
Flashmn's Avatar
Default Re: (B bOy CrAyOn)
Well the jb weld wont prevent the crack from growing.. which they have the tendency to do, I'd just take it to be properly welded still when its only minor.
Old May 31, 2005 | 09:19 PM
AmauryR's Avatar
Default Re: (Flashmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">Well the jb weld wont prevent the crack from growing.. which they have the tendency to do, I'd just take it to be properly welded still when its only minor.</TD></TR></TABLE>
I had this problem a while ago with my old gsr tranny. Long (annoying) story short, jb weld didn't work (as well as every other metal epoxy I got my hand on). Get it fixed now while you can (needs actual-weld to fix). Hope that helps, -l8r.
Old May 31, 2005 | 11:05 PM
CRXDrew's Avatar
Yea.. i'm tihnking the crack will grow. Its just the case right?
Remove the case and bring it to anyone who can weld AL and ur set.
Old Jun 1, 2005 | 05:18 PM
therealpoorboy's Avatar
Default Re: (CRXDrew)
JB weld is holding tranny cases together on pretty much every drag car out there. from minor knicks from breaking ring gears to chunks from breaking spools.
Old Jun 1, 2005 | 07:20 PM
khmboostedeh2's Avatar
Default Re: (therealpoorboy)
I JB Weld'ed the hole where my oil pressure sender was, (the threaded part [on top] broke off). Its been almost a year now and not a single leak.
Old Jun 1, 2005 | 10:30 PM
thnx for the help u guys... i JB Welded it cuzz it was the thread on the tranny where the case broke... i put JB Weld outside of it and in the thread and just threaded the bolt on there and took it off and let it dry ... its been fine... not a single leak... it was only about half an inch long and paper thin...
Old Jun 2, 2005 | 12:22 PM
own6volvos's Avatar
I would watch it like a hawk and maybe use a permanent marker to put a line to show how far the crack is now. If it ever spreads, get it welded up ASAP.
Old Jun 2, 2005 | 01:16 PM
Flashmn's Avatar
Default Re: (own6volvos)
I seriously doubt any credible drag racing team uses JB weld to patch trannies, thats just careless. Tranny case is under strain and vibration, its only a matter of time till the crack grows.
Old Jun 2, 2005 | 02:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">I seriously doubt any credible drag racing team uses JB weld to patch trannies, thats just careless. Tranny case is under strain and vibration, its only a matter of time till the crack grows. </TD></TR></TABLE>
if you put a nice size hole in a tranny, and just weld it up even if you preheat the case you will still warp it. and most of the time the spots most drag racers have small cracks are in very low stress points. if you break one of these cases at a strees point its pointless to try and weld it back up.
Old Jun 2, 2005 | 09:25 PM
Flashmn's Avatar
I bet if they put a hole in the tranny, they just get a new casing.
rmiller
Transmission & Drivetrain
Jun 7, 2011 12:57 PM
rmnS2K
10
Nov 1, 2006 11:37 AM
staticrex
Welding / Fabrication
11
Jan 7, 2005 11:13 AM
that guy steveee
Jan 6, 2004 06:13 PM
