Energy Suspension Motor Mount Bushings
Old May 27, 2005 | 10:40 PM
Bee18Hatch's Avatar
Default Energy Suspension Motor Mount Bushings
Will the Energy Suspension Motor Mount replacement bushings fit in OEM Mounts or do they have to be aftermarket?? As always, all help is appreciated..
Old May 27, 2005 | 11:11 PM
peacexisxfree's Avatar
they will fit in oem mounts.
Old May 28, 2005 | 01:48 AM
Bee18Hatch's Avatar
Default Re: (peacexisxfree)
Will they repair a torn bushing that is coming out (driver's side)?
Old May 28, 2005 | 07:23 AM
Galaxy Si's Avatar
Default Re: (Bee18Hatch)
the complete kit will replace all the major bushings, but just be ready for a major head ache and a lot of swearing.
Old May 28, 2005 | 11:47 AM
are you talkink about motor mounts or the bushing kit? and yes, it will replace a torn bushing...it will replace a lot of bushings. if youre talking about the bushing kit, which i now assume you are. if youre going to do it yourself, b18c1 is correct, be prepared for a lot of swearing.
Old May 28, 2005 | 02:01 PM
Bee18Hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peacexisxfree &raquo;</TD></TR><TR><TD CLASS="quote">are you talkink about motor mounts or the bushing kit? and yes, it will replace a torn bushing...it will replace a lot of bushings. if youre talking about the bushing kit, which i now assume you are. if youre going to do it yourself, b18c1 is correct, be prepared for a lot of swearing.</TD></TR></TABLE>
So should I just get some HASport/Avid full mount kit? And, I won't be doing most of the work, my roommate's pops is a mechanic.... So he'll be swearing.
Old May 30, 2005 | 06:59 PM
get whatever you think youll need. if youre going to have a little power under the hood and youre going to be gunning it, then go for the hasport mounts. if it just has i/h/e and you have a heavy foot...go for the energys. i almost forgot. get some window weld too...if you go with the energy mounts. silicone...and it holds GREAT!
spcrxracer
Dec 29, 2013 08:10 AM
ls_bitik
Aug 1, 2007 12:14 PM
dtrtw
May 31, 2005 05:59 PM
dtrtw
May 31, 2005 05:07 PM
91bluehatch
Mar 29, 2005 10:35 AM
