Suspension & Brakes Theory, alignment, spring rates....
front is higher than the rear..
Old May 27, 2005 | 10:15 PM
haveaniceday's Avatar
Default front is higher than the rear..
i just installed koni sp3s and neuspeed race and as the titles states the front is higher than the rear.. i started on the rear... and then did the front .. im thinking maybe it has to settle it in.. i have drove 15-20 miles on it.. j/w is this normal or not.. also i noticed the passenger side spring is off the spring seat(not sure what its called) about 1/4-1/2 inch, also the bolt thats on the shock like the shock shock under the hood.. the passenger side threaded up an inch higher than the driver side .. help me out thanks also i have it set on full soft on all 4
Old May 27, 2005 | 10:24 PM
Default Re: front is higher than the rear.. (haveaniceday)
i mean threaded down not threaded up
Old May 28, 2005 | 06:37 AM
CerealWars's Avatar
Did you install the springs backwards? Call Neuspeed and see what goes in front and what goes in the rear.
Old May 28, 2005 | 07:05 AM
CRX Lee's Avatar
Can you ake some digi pics and post them? Something is wrong here where the springs are on the wrong end (more common than you'd think) or if the order or things got out of whack when you installed it. The sooner the better and I'd suggest driving it as little as possible. There could be several causes and some could cause damage.
Old May 28, 2005 | 09:54 AM
Default Re: front is higher than the rear.. (CRX Lee)
the springs were clearly marked like the front and rear.. so thats right i know.. i dont think they could be upside down.. cause of how its seated.. i searched on here and foundone guy said he heard about it on neuspeed race.. and i heard cause the sping rates are much higher in the front.. it might take it some time to settle in.. but if it doesnt settle in i shall get some coilovers.. prolly gc .. i will post pics in a day or 2..
Old May 28, 2005 | 10:01 AM
to give the best detail of this.. the rear is almost tucking where the front has a 2 finger gap.. if the springs were backwards which im 110% sure they arent wouldnt the front be slammed... crap im pissed off looks like a ricer drop or something
Old May 28, 2005 | 10:34 AM
vtecvoodoo's Avatar
Future Texas Boy
You don`t have a huge sub box or anything in the trunk, right?
Old May 28, 2005 | 10:38 AM
Default Re: front is higher than the rear.. (vtecvoodoo)
no nothing.. no spare... its a hatchback by the way...
Old May 28, 2005 | 06:01 PM
CRX Lee's Avatar
If you have the Neuspeed Koni SP3s, they should have 5 circlip locations for the spring percha dn with those springs you should be in the middle of the 5 locations. If your perch circlips have been moved, that would do it as well.
Old May 28, 2005 | 08:03 PM
they are in the middle .. i was wondering if it would be a bad idea to move the fronts down one.. pics are coming
Old May 28, 2005 | 08:32 PM
im a stupid newb installing suspension and the seat of the spring on the front is upside down.. **not the spring but the SPRING SEAT*** gah thought id share that with you guys .. trying to learn this some how.. i just now got it.. i feel better but at the same time i feel retarded.. thanks for the help ... respond and humor me..
Old May 28, 2005 | 08:46 PM
byronl's Avatar
it's coo, everybody makes mistakes, we're only human
Old May 29, 2005 | 10:28 AM
Default Re: front is higher than the rear.. (byronl)
driving impressions: well since its fixed the ride is amazing.. i couldnt believe its this smooth... handling is great.. i knew neuspeed race would be low but i dunno it may grow on me.. plus i have 17s they dont rub.. in the future i want 16s i think itll look better and perform better overall...
Old May 30, 2005 | 06:15 AM
CerealWars's Avatar
At least you figured it out and got it fixed.
Old May 30, 2005 | 12:40 PM
Default Re: front is higher than the rear.. (CerealWars)
i was bummed out all friday night after the install bc of the height in the front.. and sunday after i figured it out.. i cant stop looking at my car..
Old May 30, 2005 | 01:06 PM
Blazin Civic's Avatar
This actually brings me an interesting question when someone said on these springs the perch should be in the middle. I am looking for a 1.5-1.75 drop but I want the spring rates of a race spring. Would I be able to get a drop like that by using neuspeed race springs and setting the perches closer to the top or would this damage the suspension. I have koni yellows btw.
Whiteintegra
Suspension & Brakes
16
May 16, 2007 03:57 PM
i97supratti
Suspension & Brakes
Jul 18, 2006 04:24 PM
Timmy!
Suspension & Brakes
Apr 19, 2006 07:23 AM
2K4K20
May 4, 2005 04:10 AM
94GsRacer
Jul 3, 2002 07:52 AM
