safety on stock engine a turbo kit w/out intercooler
Old May 27, 2005 | 05:03 PM
candyman3106's Avatar
Default safety on stock engine a turbo kit w/out intercooler
safety on stock engine a turbo kit w/out intercooler ???????? run 6 psi
Old May 27, 2005 | 05:16 PM
SilverPanda's Avatar
Default Re: safety on stock engine a turbo kit w/out intercooler (candyman3106)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by candyman3106 &raquo;</TD></TR><TR><TD CLASS="quote">safety on stock engine a turbo kit w/out intercooler ???????? run 6 psi</TD></TR></TABLE>
if you cared about your car you wouldnt get a turbo kit
Old May 27, 2005 | 05:21 PM
Nature's Renewal's Avatar
Default Re: safety on stock engine a turbo kit w/out intercooler (vtech22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtech22 &raquo;</TD></TR><TR><TD CLASS="quote">if you cared about your car you wouldnt get a turbo kit </TD></TR></TABLE> What the heck? Are you talking specifically to this guy or everyone who turbos a prelude?
Old May 27, 2005 | 05:37 PM
plikit's Avatar
theres nothing wrong with boosting a lude. you just have to know what youre doin. you probably dont want to boost a vtec unless you bore it out because with a 10:1 compression youll probably blow the motor... even with a mild boost. i dont have a boosted lude but my uncle has been using turbos and superchargers for years. the best thing to do is build the motor to suit the your boost setup. not vice versa.
Old May 27, 2005 | 06:04 PM
Default Re: safety on stock engine a turbo kit w/out intercooler (Kristoff)
no its fine to boost your lude, but turbo KITS are
Old May 27, 2005 | 06:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude &raquo;</TD></TR><TR><TD CLASS="quote">LEARN ABOUT BUILDING a motor, then you can piece everything together yourself the way it should be. Turbokits you buy from somewhere are for idiots w/ no aspirations for their car.</TD></TR></TABLE>
Old May 27, 2005 | 06:14 PM
01 LudeDude's Avatar
Default Re: safety on stock engine a turbo kit w/out intercooler (plikit)
While I agree that building the motor is a good idea, that's not to say that you can't boost a stock H22 so long as the boost is mild (6-8), and the tune is well done. Many people around here have done it successfully, including myself. If I had the option of an IC, I would certainly have one. If you plan to go turbo, then I would suggest an intercooler, even a small one. Anything you can do to lower intake temps will lessen your chances of detonation, and from what I've seen/read, that is what generally kills H22s (ring lands). Just remember that Tuning is key for your engine to last, boosted or not.
Old May 27, 2005 | 07:55 PM
jnet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by plikit &raquo;</TD></TR><TR><TD CLASS="quote">theres nothing wrong with boosting a lude. you just have to know what youre doin. you probably dont want to boost a vtec unless you bore it out because with a 10:1 compression youll probably blow the motor... even with a mild boost. i dont have a boosted lude but my uncle has been using turbos and superchargers for years. the best thing to do is build the motor to suit the your boost setup. not vice versa.</TD></TR></TABLE>
You can't just "bore it out", that requires new pistons. And forged pistons in the H22 means new sleeves, and well thats all about $1500, so you might as well throw in rods too.
Old May 27, 2005 | 08:11 PM
Dougs96SI's Avatar
Not safe at all.
Old May 28, 2005 | 10:54 AM
plikit's Avatar
Default Re: safety on stock engine a turbo kit w/out intercooler (jnet)
when i said bore it out i assumed you knew what went along with that..
i just wanted to point out 10:1 compression is a little harder to deal with when boosting a vtec. if youre going to spend your money on a turbo or supercharger setup may as well do it right.
Old May 28, 2005 | 11:21 AM
Innovation's Avatar
Default Re:
Anyone whos not willing to spend the money on a complete, efficient turbo kit will 9 times out of time... not be willing to spend the money on proper tuning/engine management.
Being cheap gets expensive when **** starts blowing up
Old May 28, 2005 | 12:11 PM
clemsoncb7's Avatar
Default Re: Re: (Innovation)
Yes, very bad idea. Those gases recirculated are hot enough as is, the only chance of saving your motor (stock bottom end) is by cooling down those charge gases and not frying your rings by using an intercooler. Even with 6psi, don't cheap out.
Old May 28, 2005 | 12:23 PM
AzCivic1.6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by plikit &raquo;</TD></TR><TR><TD CLASS="quote">when i said bore it out i assumed you knew what went along with that..
i just wanted to point out 10:1 compression is a little harder to deal with when boosting a vtec. if youre going to spend your money on a turbo or supercharger setup may as well do it right. </TD></TR></TABLE>
sooo, what does boring it out have to do with the compression????
Old May 28, 2005 | 01:18 PM
sharkcohen's Avatar
Default Re: Re: (maxvtec7500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, very bad idea. Those gases recirculated are hot enough as is, the only chance of saving your motor (stock bottom end) is by cooling down those charge gases and not frying your rings by using an intercooler. Even with 6psi, don't cheap out. </TD></TR></TABLE>
Recirculated gases?
Old May 28, 2005 | 01:59 PM
prelittlelude's Avatar
Default Re: Re: (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">
Recirculated gases? </TD></TR></TABLE>
yeah um what?
but if you don't run even a small intercooler then you going to have rediculously high intake temps and that is what aids in detonation. if you get too much or even alittle detonation on a honda motor say bye bye ring landings.
if you really didn't want to run an intercooler and you wanted to keep the intake temps down you could run water/meth injection, but something tells me that is alittle to far out of the picture for you.
xkrntamax
Jan 28, 2007 04:06 PM
egzo04
Nov 15, 2005 11:51 AM
I Like Boost
Mar 24, 2004 10:50 AM
Gmedalion
Honda S2000
18
May 7, 2003 06:04 AM
ludelvr
Apr 1, 2003 12:09 PM
