Resistor power
Old May 27, 2005 | 04:21 PM
crx1racing's Avatar
Default Resistor power
Is it true that you can run a 5200 Ohm resistor in place of your air intake temp sensor to trick the cpu into thinking its at 40 degrees?
Old May 27, 2005 | 04:27 PM
crx1racing's Avatar
Default Re: Resistor power (crx1racing)
come on, is this a bunch of **** or not? If not its cheap as hell for a mod!
Old May 27, 2005 | 04:33 PM
fireant's Avatar
I've heard of placing a resistor in-line with your sensor, but not replacing it altogether. It makes you dump more fuel into the mix.
Old May 27, 2005 | 04:36 PM
crx1racing's Avatar
Default Re: Resistor power (fireant)
so if i just do that and advance my timing about 3 degrees it should act like a chip?
Old May 27, 2005 | 04:57 PM
fireant's Avatar
I havent tried it...never heard of anyone swearing by it...you'd think if it was worthwhile everyone would be all over it after all these years. I bet its a waste.
baseball_aj
Honda Civic (2001 - 2005)
Jul 19, 2007 01:01 AM
bluelude2.3
May 20, 2007 12:29 PM
codemaster63
Jul 23, 2005 10:10 PM
litterbox
Apr 20, 2004 08:54 PM
boonacka
Nov 6, 2002 12:41 PM
