After Warm Up... Very Hard Top & Bottom Rad Hoses ?
Old May 27, 2005 | 02:34 PM
integlspwr2k's Avatar
Default After Warm Up... Very Hard Top & Bottom Rad Hoses ?
After my car warms up, the top and bottom radiator hoses are very hard.
Normally you can squeeze them, but this time I couldnt.
Anyone know what the problem might be or if there even is a problem?
Thanks In Advance.
-integlspwr-
Old May 27, 2005 | 02:38 PM
non-VTEC's Avatar
Default Re: After Warm Up... Very Hard Top & Bottom Rad Hoses ? (integlspwr2k)
air lock in the cooling system?
Old May 27, 2005 | 02:42 PM
dustin's Avatar
is the car running?
Old May 27, 2005 | 03:14 PM
CoreyR's Avatar
Default Re: After Warm Up... Very Hard Top & Bottom Rad Hoses ? (dustin)
thats normal.
Old May 27, 2005 | 03:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">is the car running?</TD></TR></TABLE>
yea the car is running when i do the squeeze test.
Old May 27, 2005 | 03:45 PM
Default Re: After Warm Up... Very Hard Top & Bottom Rad Hoses ? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">air lock in the cooling system?</TD></TR></TABLE>
i'll take off the rad cap and see if bubbles come up to the water neck.
Old May 27, 2005 | 03:48 PM
Default Re: After Warm Up... Very Hard Top & Bottom Rad Hoses ? (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">thats normal.</TD></TR></TABLE>
Anyone care to confirm?
Old May 27, 2005 | 07:36 PM
Finland's Avatar
that's normal. The higher pressure cap you use the harder the hoses will feel once the thermostat is open.
Old May 27, 2005 | 07:45 PM
Muckman's Avatar
Moderator in Chief
Old May 27, 2005 | 10:01 PM
Default Re: After Warm Up... Very Hard Top & Bottom Rad Hoses ? (Boondock Saint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint &raquo;</TD></TR><TR><TD CLASS="quote">that's normal. The higher pressure cap you use the harder the hoses will feel once the thermostat is open.</TD></TR></TABLE>
ah i c. cool. my theromostat is hollowed out right now, does that matter?
Old May 27, 2005 | 10:02 PM
Default Re: After Warm Up... Very Hard Top & Bottom Rad Hoses ? (Muckman)
thanks everyone for the reassurance..
Old May 28, 2005 | 02:54 AM
Frozen E's Avatar
H-T White Ops
It's normal. I'd be worried about a hose I can squeeze before I'd worry about one I can't. If you can't squeeze it that means your water pump is doing it's job and pumping water.
AaronJ
Sep 23, 2007 05:20 PM
a12rnulfo
Nov 14, 2006 10:17 AM
FastHatch90
Apr 3, 2006 09:35 PM
mattdenali
12
Jun 17, 2005 03:57 AM
130R
17
Dec 27, 2004 07:07 PM
