Is it bad to put warm water on a over heated engine?
Old May 27, 2005 | 12:54 PM
kenzieambrose's Avatar
Default Is it bad to put warm water on a over heated engine?
my friend and i have to different opinons on this matter and i would like to figure it out. please answer and leave a reason why or why not! that would help me a lot!!!
Old May 27, 2005 | 01:49 PM
HoUTX98GSR's Avatar
Default Re: Is it bad to put warm water on a over heated engine? (kenzieambrose)
if the water temp and the engine temp differ too much and you put alot of water on/in it it could crack your block...
Old May 27, 2005 | 04:48 PM
DaZman69's Avatar
Default Re: Is it bad to put warm water on a over heated engine? (HoUTX98GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoUTX98GSR &raquo;</TD></TR><TR><TD CLASS="quote">if the water temp and the engine temp differ too much and you put alot of water on/in it it could crack your block... </TD></TR></TABLE>
and you can bet ur *** the engine temp is a hellavu lot higher then the "warm" water temp
Old May 27, 2005 | 05:10 PM
drdisco69's Avatar
I would hazard to say that pouring ANY water on an overheated engine is like the last thing you would want to do. It's not going to cool it off, it's just going to make a mess and maybe warp it (worse than it already is).
Old May 27, 2005 | 05:31 PM
97dxnut's Avatar
Default Re: Is it bad to put warm water on a over heated engine? (drdisco69)
it certainly wouldn't help it, if there is to much of a temp dfference, it could crack your block.
I would have to say that rapidly changing the temperature of something s more dangerous than just heating it.
SPOOLINmatt
Mar 12, 2011 11:57 AM
EngineNoO9
Honda Motorcycles
15
Dec 24, 2005 11:54 AM
GZERO
Oct 23, 2002 12:30 PM
onebadld
Oct 9, 2002 09:03 PM
