HELP Blower wont turn on. Checked fuses and resistor and the blower what is the problem?
Old May 27, 2005 | 12:38 PM
DC2tuner's Avatar
I Think I'm TOO White For This Thread
Default HELP Blower wont turn on. Checked fuses and resistor and the blower what is the problem?
the fuses are good i replaced the resistor and i took out the blower and hooked up direct power and it turned on. wtf is the problem? is it the switch? i need help real bad i live in cali and its 98 degrees and i have leather interior im burning. please help
Old May 27, 2005 | 12:47 PM
Racermech's Avatar
Default Re: HELP Blower wont turn on. Checked fuses and resistor and the blower what is the problem? (Projec
https://honda-tech.com/zerothread?id=1259552
Starting a new thread does not help......just update the old one.
But anyways. You hard wired the actuall blower so that is fine. Does the selector work. I mean the one that selects face, face feet,feet.....etc???
Have you ever removed the vent console?? If so did you plyg it back in all the way? Till the plug "clicks" into place??
Old May 27, 2005 | 12:53 PM
DC2tuner's Avatar
well its not all put back as of now im trying to get it working before i put it all back together. the only reason i hardwired it to the battery was to make sure the blower is still good. i changed out the resistor. i checked the fuses and the blower will ocassionally turn on and off whenever it wants.
Old May 27, 2005 | 01:01 PM
Racermech's Avatar
kinda sounds like a bad ground, or a loose wire at the blower. I kina doubt the controler switch has anything to do with it
Old May 27, 2005 | 01:07 PM
DC2tuner's Avatar
i know its not a loose wire at the blower because i removed the blower and it is sitting on the floor plugged in. where would that ground be?
Old May 27, 2005 | 01:36 PM
DC2tuner's Avatar
Old May 27, 2005 | 02:32 PM
DC2tuner's Avatar
i unhooked the blower for thr a/c. i hooked up the terminals to the battery. the blower turned on. therefore the blower is still good. i checked the fuses. they are all good. i changed out the blower resistor. now i am stuck. it comes on randomly and i dont know whats wrong. is there a relay i should check. where is it if there is one what else do you guys sugest?
Old May 27, 2005 | 04:55 PM
Sam92Teg's Avatar
I wonder if the strong current directly from the battery can operate it, but when you hook it up in the car, the current isn't enough. Dunno, shot in the dark.
COMplex.
Jul 28, 2014 04:06 PM
honda dan
Dec 22, 2011 01:54 PM
jonessw20
May 4, 2010 10:25 AM
KDoGx504
Sep 28, 2005 06:34 PM
inigo
Aug 26, 2004 02:11 AM
