wiring up jdm non hid turn signals. got the driver's side, passenger side is wack!
Old May 27, 2005 | 12:27 PM
IntegraXTR's Avatar
Default wiring up jdm non hid turn signals. got the driver's side, passenger side is wack!
ok...i dunno what's going on, but my drivers side is working perfectly.
the sidemarkers don't turn on when you click once (jdm style yo haha). and everything on the drivers side works.
question is, there is no power on the passenger side when you click the headlights on. the turn signal sections work, but the two power wires don't seem to be powering up.
i checked the fuses, is there anything else that could've happened?
Old May 27, 2005 | 02:54 PM
apok's Avatar
Default Re: wiring up jdm non hid turn signals. got the driver's side, passenger side is wack! (IntegraXTR)
Get a test light and make sure that power is coiming through the wires.
Old May 27, 2005 | 03:35 PM
IntegraXTR's Avatar
there's no power at all. i just took the turn signal bulb out and put it on and it doesn't light up :/
Old May 27, 2005 | 03:41 PM
Dforce's Avatar
That's what she said!
check your wiring. i had the same problem.
Old May 27, 2005 | 06:46 PM
IntegraXTR's Avatar
thanks for the reply....
anybody else?
Old May 27, 2005 | 09:58 PM
Naruto's Avatar
Default Re: (IntegraXTR)
I haven't had this problem though ( yet )....but what year is your integra? If you've checked ALL fuses and all slots for fuses ( making sure none is missing where one should be ), then definitely check the wiring. Its a bitch to do....but its at least a step in the right direction. Who knows....maybe a connection has been severed somewhere....only one way to find out.
Old May 28, 2005 | 01:35 AM
IntegraXTR's Avatar
mine is a 2000 gsr.
yeah, i went and checked the fuses under the steering column and the engine bay one.
i hope the connection didn't severe somewhere, since i think it may have power before. i have no clue where that line comes from haha
Old May 28, 2005 | 12:30 PM
Naruto's Avatar
its ok....just try and find a wiring diagram to start If you can read it without rotating the page 4 to 5 times , then you're off to a good start
Old May 29, 2005 | 01:41 PM
IntegraXTR's Avatar
haha i'll have to look at my service manual :/
=P
Old May 29, 2005 | 07:31 PM
IntegraXTR's Avatar
hmm, too apart the looming and found out that there's only one red wire. where the **** is the other one :/
Old May 30, 2005 | 04:05 PM
IntegraXTR's Avatar
went to the main harness and there's only one red wire with a black stripe.....anybody know?
Old Jun 2, 2005 | 01:30 PM
IntegraXTR's Avatar
driver's side has two red wires with black stripe (traced the harness)
the passenger side only has one red wire with a black stripe.
confusedddddddddddd
Old Jun 3, 2005 | 11:17 AM
IntegraXTR's Avatar
someone help haha
Old Jun 4, 2005 | 02:46 PM
Naruto's Avatar
man....can't even differentiate between power or ground I'm not too familiar with the wiring on your year....mine is a 96 so it had several wires. In fact....I'm hoping that whoever did your front end install didn't end up cutting some wires....
If I remember correctly there should be at least 3- 4 wires from where your original bumper lights were on either side ( of the USDM front end ). The fact that you have 2 of the same on one side and only one on the other.....baffles me. Is the wiring THAT much different from the 98-01 tegs for the turn signals??? Someone please clarify!
Old Jun 4, 2005 | 03:22 PM
IntegraXTR's Avatar
yeah, i HIGHLY doubt that there's a difference between the 98 and 96 DC2s :/
there's supposed to be two red wires with black lines down to the turn signals from what i know.
augh haha.
Old Jun 4, 2005 | 03:58 PM
Naruto's Avatar
well....from my basic and little knowledge of electronics....you should have had at the very least a power and ground for each of the bulbs in your corners from the original USDM front end. I do believe there was another wire ( accessory ) that helped it to flash? when the signals were on. From what you posted.....sounds like you're missing some wires.....somewhere......
I could be wrong though.....
Old Jun 5, 2005 | 11:38 AM
IntegraXTR's Avatar
yes, the wire that makes it flash is green.
i dunno why there's a missing wire because i traced it back to the harness.
there's only one power and one turn signal wire. the other side has two powers.
so confused haha
AudioFunk
May 19, 2015 11:16 AM
Charismatica
Lighting
Jun 20, 2014 09:18 AM
dlewis2583
Oct 7, 2010 09:34 AM
xyk
Dec 25, 2009 01:18 PM
