Rev limit and fuel cut off?
Old May 27, 2005 | 12:27 PM
annoying thing's Avatar
Default ITR REV LIMIT AND FUEL CUT OFF?????
Can some one help? Where does the rev limit bounce at, the fuel cut off, and Vtec activation point?
Thanks
Old May 27, 2005 | 12:31 PM
aziantegger10's Avatar
Default Re: ITR REV LIMIT AND FUEL CUT OFF????? (annoying thing)
try it and find out
Old May 27, 2005 | 12:46 PM
Default Re: ITR REV LIMIT AND FUEL CUT OFF????? (aziantegger10)
I can't cause it's going in my eg. Going to be obd1 with a reprogramed P72. Thats why i need the specs
Thanks
Old May 27, 2005 | 02:55 PM
Black Raven
Guest
Posts: n/a
the redline is at 8400 and the fuel cut is at 8500, i think vtec engages at 5800
Old May 27, 2005 | 02:57 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by annoying thing &raquo;</TD></TR><TR><TD CLASS="quote">Can some one help? Where does the rev limit bounce at, the fuel cut off, and Vtec activation point?
Thanks</TD></TR></TABLE>
» Search Results
Your search for rev limit returned 11 results.
» Search Results
Your search for fuel cutoff returned 6 results.
» Search Results
Your search for vtec engagement returned 17 results.
Old May 27, 2005 | 07:39 PM
nautica_t's Avatar
Default Re: ITR REV LIMIT AND FUEL CUT OFF????? (An Jing Ren Jerh)
iunno on the 01 its 8700 red and i think round 9000 for fuel cut off
can't remember. .
Old May 27, 2005 | 08:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by An Jing Ren Jerh &raquo;</TD></TR><TR><TD CLASS="quote">the redline is at 8400 and the fuel cut is at 8500, i think vtec engages at 5800</TD></TR></TABLE>
sounds more like a gsr, i thought gsr's redlined at 8100 and cut off around 85? i believe my R cuts at 9100
Old May 27, 2005 | 09:54 PM
mugenracer's Avatar
Standard ITR, rev limit/fuel cut at 8900rpm, redline at 8400rpm and vtec x-over at 5800rpm
Old May 28, 2005 | 07:53 AM
MOVE OVER's Avatar
Default Re: (mugenracer)
when i searched for that a while back i came up with 8400 redline, 8500 fuel cut off, and 5700 vtec engagement point
i think people will agree that the stock guages are not exactly accurate and maybee that is why there is some contraversy on the factory rpm settings
i cant tell vtec till exactly 6000 rpm's and fuel cut off is pretty far past 8500 - but thats judjing by feel and watching my tach
ANYONE?? will a VAFC or VAFCII tell u the stock points for these when installed?
how else can u test this yourself without buying aftermarket guages?
p.s. the v card is BA while driving across the country
Old May 28, 2005 | 02:18 PM
Ill's Avatar
Ill
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">Standard ITR, rev limit/fuel cut at 8900rpm, redline at 8400rpm and vtec x-over at 5800rpm</TD></TR></TABLE>
+1
Search!
+2
I hope that's JDM ITR, or you have proof it's legit.
Old May 28, 2005 | 10:15 PM
Azcheron's Avatar
Default Re: (Ill)
Here is the CORRECT information
if your car is different than your tach is wrong or your not stock
Vtec = 5800
redline = 8400
fuel cut = 8600
some say 8500 fuel cut, but its 8600
geeman640
Honda Civic (2006 - 2015)
13
Oct 5, 2007 12:00 PM
BlakeJ53
11
Dec 24, 2006 07:13 AM
CleanLIttleLude
Feb 6, 2004 09:40 PM
itr1244
Sep 15, 2002 09:16 PM
weakGOODJunKieS.com
Aug 4, 2002 11:10 PM
