ITR 5lug suspension, can use with 2k Si struts?
I have newly installed Omni power coilovers on my 2k Si.
If I install a ITR 5lug suspension, can I still use those Omni full coilovers that are meant for my 2k Si ?
Im pretty sure I know the answer...but I wanna make sure before I go off and blow more cash.
thanks.
thanks.
Your not going to want to change the front LCA's & sway-bar (since the Si swaybar is bigger than the Type R), and you cant change the rear LCA's since EK are each an inch longer than EG/DC ones. This means you have to keep your same shocks too.
When doing the swap, you only need to change the front steering knuckles and the rear trailing arms. Then your 5 luggin' all the home...
cool. thanks!!!!!!!!!!!!!!!!!!!
what about the brakes from ITR to my 2k Si ?
I've read that I need to change the master cylinder and such?
REVolution
Dec 23, 2002 06:24 PM
