dynamic toe change in the rear of EP3 under compression
Old May 27, 2005 | 08:07 AM
Burgh's Avatar
Default dynamic toe change in the rear of EP3 under compression
So as I understand it, the EP3 rear suspension toe's out under compression (i.e., when you get on the gas and transfer weight to the back). All the older civics toe out under rebound (i.e., when you transfer weight off the back). What's the details behind this difference?
Old May 28, 2005 | 07:45 AM
Halo's Avatar
Default Re: dynamic toe change in the rear of EP3 under compression (Burgh)
where did you hear that? I don't see why it would
Old May 31, 2005 | 08:43 AM
Burgh's Avatar
Default Re: dynamic toe change in the rear of EP3 under compression (Halo)
From a few folks that I autocross with. Apparently, the newer celicas do the same thing.
Old May 31, 2005 | 02:13 PM
funz0rzies's Avatar
is this on a stock suspension or even aftermarket's do it...
Old Jun 1, 2005 | 08:17 AM
Burgh's Avatar
Default Re: (blackdc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdc5 &raquo;</TD></TR><TR><TD CLASS="quote">Under compression, the rear suspension toe's in.
The fronts, since we're talking about dynamic alignment changes under compression, will tend to toe out during compression... </TD></TR></TABLE>
Really??? I thought it was the other way around. Front toe-in during compression and rear toe out during compression.
Old Jun 1, 2005 | 12:40 PM
Phil B's Avatar
Default Re: (Burgh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burgh &raquo;</TD></TR><TR><TD CLASS="quote">
slight tangent: that would be kind of like passive 4ws, right?
Old Jun 1, 2005 | 03:21 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: (Barabus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Barabus &raquo;</TD></TR><TR><TD CLASS="quote">
slight tangent: that would be kind of like passive 4ws, right?</TD></TR></TABLE>
It's not the kind of steering change you want, though.
If you're at, say, 135-140 and need to go into threshold braking to slow to, say, 45 to make a turn on a track, your tread patch at the front becomes HUGE at the same time you've gone positive camber and toe-out in the rear.
This can make for a very nerve wracking couple of seconds while the car slows down because you feel that if you even breathe wrong the car's going to go shooting off in another direction.
This is why you'll find yourself wanting to change your suspension alignment theory as you get faster on road courses.
ef_si
Jul 25, 2013 02:09 PM
dc4teg95
Nov 6, 2007 04:18 AM
Combustion Contraption
53
Nov 18, 2006 09:50 PM
1.8T_EG
Jul 6, 2004 08:27 AM
ITR.00-1282
Mar 30, 2003 09:04 AM
