Miller's LS\Vtec
My build
B16a Head w/ GSR cams
B18b Block w/ PR3 pistons mounted on stock ls rods
Here's my parts list thus far:
Golden Eagle LS\Vtec kit
PR3 Honda OEM Piston Ringset
ACL Bearings
Golden Eagle Head Studs
ITR Oil Pump
ITR Water Pump
ITR T-belt
ARP Rod Bolts
ITR Intake Manifold
B18b TB bored by maxbore
N1 Crank Pully
Once I get a little more cash I plan on upgrade my valvetrain also.
My B18b1 block.
Adios crappy ls head (ignore the white eg in the back... it's not going in that)
Removing the B18 rods
B18 rods and pistons on top B16 rods and pistons on the bottom.
My pistons back from the machinist. They really turned out great!
Throttle body bored by Jorge at Maxbore. Bored to 64mm.
Golden Eagle "HD" Headstuds w/ glass bead finish
New oil pump, water pump and tensioner installed
Old B16 ..... pulled
PR3 pistons installed w/ new rings in freshly honed cylinders
Rebuilt tranny mounted on b18 bottom end and installed
Head finally installed
A lot of little things to finish up but for the most part she's in!
It's sitting a bit higher than the B16 that was in there before. Looks like I'll be cutting the hood a little.
Slicks and rims finally came too.
Modified by miller.91.HB at 12:14 PM 5/27/2005
ACL Bearings
ITR Oil Pump
ITR Water Pump
ITR T-belt
ARP Rod Bolts
ITR Intake Manifold
N1 Crank Pully
My B18b1 block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrevnef »</TD></TR><TR><TD CLASS="quote">good **** man. cant wait to see some times on that beast.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTU litterbox »</TD></TR><TR><TD CLASS="quote">What tranny are you using?</TD></TR></TABLE>
I've got a YS1 right now, but I'm having some major problems with it. I'll either rebuild it or just swap in a S1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTU litterbox »</TD></TR><TR><TD CLASS="quote">I love threads like this. </TD></TR></TABLE>
dc4teg95
Sep 26, 2008 11:51 AM
OPTION2ek V.2
11
Apr 26, 2005 06:18 PM
