Eibach Sportline or H&R Race with koni yellows TOO LOW??
Old May 27, 2005 | 06:32 AM
krnfly2damoon's Avatar
Default Eibach Sportline or H&R Race with koni yellows TOO LOW??
i have koni yellows, and im choosing between eibach sportline and h&r race, but are those springs too low for 4th gen? does it have enough suspension travel? if its too low, is there a way for me to use them without messing up my car?
Old May 27, 2005 | 07:11 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Eibach Sportline or H&R Race with koni yellows TOO LOW?? (krnfly2damoon)
Get customized higher (stiffer) spring rates. There are potholes in CA?
Old May 27, 2005 | 01:29 PM
boostedlude97's Avatar
Default Re: Eibach Sportline or H&R Race with koni yellows TOO LOW?? (Sticky Tires)
i wouldn't recomend the sportlines....reason being they are meant for a good drop with stock shocks. If ur going to spend the money on Koni's then get a good spring that will work with them accordingly. maybe the eibach prokit or Tanabe Gripfeeling. i have had both and love them . the Prokit looked lower than stock and the Gripfeeling looked stock..........so i cut them...LOL
Old May 27, 2005 | 01:50 PM
dreams190's Avatar
Default Re: Eibach Sportline or H&R Race with koni yellows TOO LOW?? (boostedlude97)
I have koni yellows and sportlines and i have no problems at all, if you want pics, look at page 21 of the prelude pictures thread at the bottom...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedlude97 &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't recomend the sportlines....reason being they are meant for a good drop with stock shocks. If ur going to spend the money on Koni's then get a good spring that will work with them accordingly. maybe the eibach prokit or Tanabe Gripfeeling. </TD></TR></TABLE>
wtf are you talkin about!?! sportlines with stock shocks would be a nightmare!! sportlines drop the car more than the pro-kit does!!!
Old May 27, 2005 | 02:40 PM
Altilude's Avatar
Default Re: Eibach Sportline or H&R Race with koni yellows TOO LOW?? (dreams190)
i have sportlines and kyb agx... i don't think the drop is crazy drastic or anything - and I drive in some bumpy places... (; the ride is somewhat firmer (obviously) but my comfort level in the car hasn't really changed at all - that is with stock rubber. I was actually quite amazed - I was exspecting to be jutted around after all the threads I read on here. - I imagine it will roughen up when I put different rubber/rims on. - sportlines are only 1.7/1.5 - it's not like you're going over 2 inches.
Old May 27, 2005 | 02:49 PM
Default Re: Eibach Sportline or H&R Race with koni yellows TOO LOW?? (Altilude)
yeah i had sportlines on stock struts for about six months before i upgraded to Koni's and Prokit
never had a problem with them. i like the abiltiy to change the lower spring perch on the koni's . i was able to obtain the drop that i was wanting with the prokit
Old May 27, 2005 | 05:38 PM
omgdudewtf's Avatar
I'm installing my sportlines and kyb gr-2's next week. Glad to hear some opinions on them.
Old May 27, 2005 | 06:09 PM
PnoyJeff's Avatar
Default Re: (omgdudewtf)
** This is Ralpheyizzle on my brother's username. **
I have the Sportlines on my stock shocks. It's not as bad as some people made it out to be. I plan to get some Tokico Illuminas to use with my Sportlines. I heard they're good.
Old May 27, 2005 | 06:23 PM
ludedude48's Avatar
Default Re: (DA notorious G.S.R)
I wish someone had given me some pics of a 4th gen with 1.5" rear lowering...
here goes: eibach sportline with tokico illumina 5 and 17x7.5 215 40r17
http://is.rely.net/1-452-22517...w.jpg
http://is.rely.net/1-452-22519...A.jpg
a Camber kit is definately needed for the rear. it looks better too.
Old May 27, 2005 | 06:49 PM
BeanBag64's Avatar
Default Re: (ludedude48)
I have Koni Yellows and H&R race springs... Its a bit too low for my tastes. I cant get on any lifts, and no jacks fit under it. My header is dented up, resonators and can hit the ground every so often. I say get something at least .5" higher.
Old May 27, 2005 | 07:57 PM
ludedude48's Avatar
Default Re: (ofthesun93)
how low did the H&R race go?
( i must say, a lower car IMO is worth the possible drawbacks, when I am driving, cornering ect.)
Old May 27, 2005 | 10:23 PM
KYB GR-2's are a great replacement for stock struts. they don't last long on a big drop like that of which u obtain with the sportlines. a better choice would have been a nice set of Tokico blues.
Old May 28, 2005 | 01:01 AM
Lude4Raj's Avatar
im planning also to get some sportlines. I already have Tokico blues. Will it require me to get chamber kits?
Sorry for the jack.
Old May 28, 2005 | 02:14 AM
diluted's Avatar
sup, i have h&r race springs w/ the stock shocks and i can vouch that its pretty low. the drop for a 4th gen is 1.9/1.6. the springs leave the back a tiny bit higher than the front, about a finger gap more, which isn't really accurate to judge it by. w/ these springs your gonna want to get a camber kit for the rear at least. the spring rates hold the car pretty nice, but personally id opt for some custom rate ground control sleeves. but if thats not an option, id stick to the h&r's if u want a nice low car. and since u have koni yellow's, you can drop the rear a little bit lower w/ those adjustable perches, just to even out the drop.
Old May 28, 2005 | 08:33 AM
Default Re: Eibach Sportline or H&R Race with koni yellows TOO LOW?? (diluted)
thx so much for replies!! would you guys recommend H&R RACE or SPORTLINE if its just for daily driving? which spring rates would be better for a little bit more comfortable but also great cornering? thx so much!!
Old May 28, 2005 | 12:38 PM
iwhichisme's Avatar
does anyone have any pics ot the 5th gem prelude with the sportlines?
Old May 28, 2005 | 12:49 PM
blk97lude's Avatar
Default Re: Eibach Sportline or H&R Race with koni yellows TOO LOW?? (iwhichisme)
I currently have Koni yellows with H&R race springs they are freakin great
Old May 28, 2005 | 01:17 PM
Altilude's Avatar
Default Re: (Lude4Raj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">im planning also to get some sportlines. I already have Tokico blues. Will it require me to get chamber kits?
Sorry for the jack. </TD></TR></TABLE>
I don't think you'll need a camber kit unless you drop greater than 2" - and just from eyeballing my lude (kyb agx/sportlines) I'm not planning on getting one - but i'll have to check tread wear in a bit to say for sure if that's a fair assessment or not - as really i've just put these things on, so it might settle a bit more in the next month or so.
Old May 28, 2005 | 02:16 PM
ludedude48's Avatar
Default Re: (Altilude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altilude &raquo;</TD></TR><TR><TD CLASS="quote">
here are pics of what 1.5" rear lowering did without camber kits...
http://is.rely.net/1-452-22575...A.jpg
that is 4 and a half months without camber kits. yes the tires were getting on the old side, and that is the only reason that i didnt install them when i installed the sportlines.
IMO, i think that it looks **** poor to have lowered carswith xtreme negative camber. some real cheapskates out there
Old May 28, 2005 | 09:21 PM
Altilude's Avatar
it's surprising that it did that with only a 1.5" drop - and like i said, I'm going to assess (heh looks like a funny word when typed) the tread wear - obviously eyeballing the camber is a bad way to go about it - but at this point i'm not even aligned since the lowering job cuz i gotta make it to a honda dealership for 4ws, and there ain't one in my town - i'll take there advice/tread wear into consideration and take it from there, i'm not going to just chuck on possibly unnecessary expensive hardware - that requires *further* adjusting , for the hell of it - but if it's beneficial to my particular drop/pocket book (in tire) of course i will.
Old May 28, 2005 | 11:24 PM
Lude4Raj's Avatar
thanks guys. So ill try it with out the chamber kits for a lil bit and get some in the in a month or 2. Cant for my sporlines now.
Again sorry for the thread jack. Thanks guys
Old May 29, 2005 | 07:48 PM
ludedude48's Avatar
thats what i did, wait untill i had the wheels i wanted and winter was over. i had the new wheels on for a week b4 i had the camber adjusted...it killed me to know that my rear tires were being killed like that, even if i couldnt see it.
Old May 31, 2005 | 10:11 AM
what are some good camber kits?
and how do i check if i have camber kits or not cuz the previous owner told me that the car already had camber kits, thanks
Old May 31, 2005 | 10:13 AM
* B A N N E D *
Default Re: (krnfly2damoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krnfly2damoon &raquo;</TD></TR><TR><TD CLASS="quote">what are some good camber kits?
and how do i check if i have camber kits or not cuz the previous owner told me that the car already had camber kits, thanks</TD></TR></TABLE>
Ingall's are good. Shakes (member on here) might still have some for sale.
IMO, screw a camber kit. Search about it in archives. Some people suggest them, some don't.
Old May 31, 2005 | 10:16 AM
Default Re: (Sticky Tires)
dang, thx for the hella quick reply! and thx for the info!
