What Would You Techs Reccomend???
Which gasket should I get for my B18B LS Non-VTEC Turbo Integra??? I've heard good things about Cometic, or just going with the OEM gasket from Honda. I was wondering if a thicker head gasket will lower or raise the compression, also should i get a thicker head gasket for my application? If so, what thickness is good? Also, do you know what bore a stock B18B LS motor is??? I'm thinking it's 81mm but I need reassurance and a Haynes Manual! Let me know guys! Really appreciate it!
-Dj
-Dj
Sounds like we have the same setup.. I just bought a cosmetic one from civicross, he had a good price on them, and they're heavy duty.
and yeah your bore is 81mm on that block.
You can also go with a Cometic or OEM gasket. It's a bit hard to beat the quality of an OEM one. I just ordered an OEM gasket to be bored out to 84mm for my Type R turbo.
I didn't get a Cometic. I got an OEM gasket. Here is a link for the specs.
http://lib.store.yahoo.com/lib...t.jpg
Eghatchgsr8
Sep 19, 2014 02:24 PM
