oem honda lsd in b16 tranny with ls final drive
Old May 26, 2005 | 07:23 PM
coconutsoldier's Avatar
Default oem honda lsd in b16 tranny with ls final drive
I am no expert at transmissions, so I was wondering if someone could help
me with this. I am wondering if I put a honda lsd in a b16 hydro tranny
equipped with a integra ls 5th gear and final drive will operate just like it
all came from the factory like that. Do I need to worry about grinding or
the gears not meshing well or anything like that?
Thanks for any help.
Old May 26, 2005 | 07:51 PM
Suck my DX's Avatar
Default Re: oem honda lsd in b16 tranny with ls final drive (coconutsoldier)
arent all B series tranny parts compatable..i dont see why there would be a problem
Old Jun 7, 2005 | 11:14 PM
jwyoung's Avatar
where did you get your ls 5th gear?? anybody? i'm doing the same.. and want to get a gsr or ls 5th
Old Jun 8, 2005 | 03:09 AM
StupidSlowRSX's Avatar
Default Re: oem honda lsd in b16 tranny with ls final drive (jwyoung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coconutsoldier &raquo;</TD></TR><TR><TD CLASS="quote">I am no expert at transmissions, so I was wondering if someone could help
Thanks for any help.</TD></TR></TABLE>
Not trying to be a dick.. But you realize you would be making your car MUCH SLOWER with an LS final drive &gt;_&lt;
Old Jun 8, 2005 | 03:02 PM
Default Re: oem honda lsd in b16 tranny with ls final drive (StupidSlowCRX)
With the ls final, I think only 5th gear would be the only really big difference.
I could live with the others. And the only reason I was wondering about that is
because the trans that I was trying to puchase already had a ls 5th gear and final
drive. But now I am just looking for a ls 5th gear with the stock b16 4.4 final.
Old Jun 8, 2005 | 07:48 PM
95lstegman's Avatar
okay, for you guys, here are the FACTS:
1) the 4.266 LS final drive is not appreciably slower than a B16 or GSR 4.40. i just swapped my 4.266 to 4.40 and i can't even tell the difference. it's 1mph difference in first gear, 2mph in second, 3mph in third, 4mph in fourth, and 5mph in fifth. basically, peanuts.
2) NO factory Honda LSD will fit the LS or B16 final drive. only GSR, Type-R, or B16's that happen to have had an LSD from the factory. the ring gear on LS and non-LSD B16's is physically too small to fit around the Honda LSD.
so, basically, you CAN'T have a factory Honda LSD AND an LS final drive. if you bought a quaife or OBX LSD for LS/B16 you could, however. even so, the LS final drive is not different enough from the 4.40 final drive to warrant bothering to change it over in the first place.
Old Jun 11, 2005 | 12:27 PM
Default Re: oem honda lsd in b16 tranny with ls final drive (95lstegman)
Thanks for that info.
Old Jul 2, 2005 | 03:50 AM
rudebwoy's Avatar
I bought a civic type r lsd that came with a final drive, cant I just install it in my b16a tranny without changing anything? using all b16 parts? I need to know bad my tranny is in peices and wont reassemle
Toy Civic
Jun 27, 2014 11:05 AM
civicboy1128
Jun 18, 2008 04:24 AM
crowder13
Oct 8, 2007 10:57 PM
Vtecme92
Aug 3, 2005 02:46 PM
bumpin_bass
Jan 25, 2005 09:00 AM
