Honda S2000 Honda S2000
Does I/H make CEL goes on??
Old May 26, 2005 | 07:21 PM
CNS2000's Avatar
Default Does I/H make CEL goes on??
Does adding an Header and an Intake make the check engine go on???
If so, what can I do to make it go back off??
Thanks
Old May 26, 2005 | 07:31 PM
revhi's Avatar
It shoudnt, unless one of the vacuum lines is backwards or soemthing on the intake. Pull the CEL code and see what it is.
Old May 26, 2005 | 08:16 PM
papa5murf's Avatar
Default Re: Does I/H make CEL goes on?? (CNS2000)
you should be fine
Old May 26, 2005 | 09:19 PM
Francesco's Avatar
Default Re: Does I/H make CEL goes on?? (03s2kblue)
no...it will not go on...
Old May 27, 2005 | 08:11 AM
WowOzYouRock's Avatar
Default Re: Does I/H make CEL goes on?? (Francesco)
mine did ... put all the sersors and cat back in place and the CEL came on ... its the O2 not sensing the exhaust gas properly ... same thing happen to my friends car .. weird ..
Old May 27, 2005 | 08:09 PM
pierceman's Avatar
if installed correct, no cels should come on. what code is it pulling. you can pull a fuse to reset it, but if there is something wrong, it will be back within 15 mins of driving. I think the fuse is on the left side of the box 3rd one down from the top. can anyone back me on that fuse location?
MAtt
tercelrcr
Sep 18, 2018 05:11 PM
greeen ranger
Jun 16, 2013 06:38 PM
Malakai
Mar 16, 2005 02:52 PM
Bbasso
Jan 1, 2003 03:21 PM
B18C-RnVA
Apr 1, 2002 09:31 PM
