Switching to 96-00 intake manifold-anything I need to change???
I ask because as I was porting this I realized the fuel rail is different then the one on my 93 si. Everything alse looks the same but is there really anything else I need to change.
Also it seems there is a brace holding the intake manifold. Can't tell for sure since it's underneith. I'm pretty sure this will not fit the new manifold. Is this gonna be a problem?
So yeah if anyone knows what other problems I should look out for let me know. It does look pretty straight forward though.
i think it will fit cause i did it on my cousins 92 LX
we used a 98 ex intake manifold
i dont remember having any trouble other than a little custom throttle body cable holder which was a snap makin with a the flat metal peice that comes with after market intakes, a vice, some plyers, an a drill with a good metal bit
it gave the LX way better top end but not much in the lower rpms but that
was a none vtec motor
with ur si vtec motor it should be way better when the vtec kicks in
o ya an that brace screw u dont need it
an do a lil intake manifold leak test when done (use a can of brake dust cleaner 2 spay around the connection of the manifold 2 the head while the car is running and if it changes idle there is a leak and if it idles funny b4 u do this u should check th iacv-idle air control valve,or vaccum hoes, or adjust the distrubuter time 4 more top end
hope it works out 4 u
was a none vtec motorwith ur si vtec motor it should be way better when the vtec kicks in
on the turbo subject my cousin turboed his lx sedan 1.5l bootleg as hell wit radiator hoses an a ford probe turbo wit no intercooler an it was so hell it beat the **** out of this guted 95 coupe wit type r motor
that was all good 4 about 2 months then the turbo overheated an the housing cracked an put the motor back 2 stock an 2 weeks later the motor sounded like a ****** hammer beatin on a can of rocks
we dropped that motor an put in my 92 dx hatch motor wit 205,000 an added that same ex intake manifold a fendiza flywheel an a stage 3 act clutch an from what i hear he is back out cleanin people up on the streets in a rust bucket sedan wit a 205,000 mile N/A motor
lesson learned sohc motors r very relyable an strong til u deside 2 put some busted *** homade turbo kit on them so make sure u do urs right
i think my 92 dx hatch isnt cutting it with my 94 ls teg motor maybe i should get a jdm sohc my boy has one that eats up my other boys 2000 si
turboman
May 28, 2005 08:26 AM
GOLDBERG
17
Nov 30, 2004 05:09 PM
