Will 225/45/16 tyre scratch inner guard of ITR?
Old May 26, 2005 | 05:37 PM
Edward's Avatar
Default Will 225/45/16 tyre scratch inner guard of ITR?
I am planning to try D02G 225/45/16. Not sure it will scratch inner guard or not?
Old May 26, 2005 | 06:36 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: Will 225/45/16 tyre scratch inner guard of ITR? (Edward)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edward &raquo;</TD></TR><TR><TD CLASS="quote">I am planning to try D02G 225/45/16. Not sure it will scratch inner guard or not?</TD></TR></TABLE>
It's hard to be sure because of all the different suspensions at all the different ride heights, and all the different offsets of wheels.
Victor reports from the drive to Expo earlier today that he ran across someone with 225-45-16 Hankooks at all corners, and no problems at all.
But...it depends....
Old May 27, 2005 | 06:12 AM
typer_801's Avatar
Default Re: Will 225/45/16 tyre scratch inner guard of ITR? (George Knighton)
It depends on the tire, wheel width, offset, amout of lowering, camber, etc.
I'm running Hankook 225/45/16's up front on my ITR on 8" wide wheels, 50mm offset. I'm also running a little more camber than normal (close to 3 degrees). I've got plenty of room up front for more tire. With a lower wheel offset or less camber it will get more snug on the outer edge. I also rolled the inner fender tab for additional clearance.
Rear is much more snug, but I'm running same wheels, plus 8mm spacer, and &lt;1 degree negative camber. It's very close with the rear fenders rolled. Even required a little bumper trimming on the inside where it mounts to the body.
From my calculations every degree of camber you add or subtract you gain or lose .2 inches of clearance. So with more camber in the rear you could probably get away with the 225's at least in a Hankook.
01_ITR
Jan 13, 2009 08:54 PM
elitesi8
Aug 20, 2006 01:23 AM
Boostage
13
Nov 30, 2005 01:43 PM
Halo
Dec 25, 2004 04:29 PM
Xia0w0ng
Nov 18, 2003 04:53 PM
