PR3 ECU Mod.
Old May 26, 2005 | 05:14 PM
smash fascism's Avatar
Default PR3 ECU Mod.
What can be eleminated by modifying the PR3? Like ELD and VSS and the Knock sensor. what else? IM doing a B16 swap in my 87 Crx Si and I want to wire as least as possible.
Thanks, Matt
Old May 27, 2005 | 06:37 PM
bump
Old May 27, 2005 | 09:44 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: PR3 ECU Mod. (smash fascism)
Just wire it the way it is supposed to be, How are you going to eliminate the vss, and the knock sensor is there for good reason
Old May 28, 2005 | 11:29 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smash fascism &raquo;</TD></TR><TR><TD CLASS="quote">What can be eleminated by modifying the PR3? Like ELD and VSS and the Knock sensor. what else? IM doing a B16 swap in my 87 Crx Si and I want to wire as least as possible.
Thanks, Matt</TD></TR></TABLE>
I can disable these items in PR3 programming:
- knock sensor
- VTPS
- speed limiter
- 2nd 02
All you would need to do for wiring is wire in the single VTEC solenoid wire and VTEC will work.
BILLisCHILL
May 8, 2008 06:40 PM
jdmdseries
Nov 16, 2007 03:46 PM
sir2sol
May 12, 2007 05:32 AM
nub_pwn
Nov 18, 2006 11:48 PM
b16egva
Feb 23, 2006 05:33 PM
