Please HELP!!!! MICROPOLISHING CRANK MESS UP OIL BEARING CLEARENCES?
Old May 26, 2005 | 04:58 PM
ejcivicdee's Avatar
Default Please HELP!!!! MICROPOLISHING CRANK MESS UP OIL BEARING CLEARENCES?
MY QUESTION IS DOES MICROPOLISHING A CRANK MESS UP THE OIL BEARING CLEARENES? IF SO DO YOU NEED OVER SIZED BEARINGS. I ALREADY PURCHASED STANDARD SIZE ACL BEARINGS AND I WAS WONDERING IF THE MICROPOLISIHNG WILL MESS UP THE OIL BEARING CLEARENCES. pLEASE HELP ASAP.
Old May 26, 2005 | 06:45 PM
SlowReaction's Avatar
Default Re: Please HELP!!!! MICROPOLISHING CRANK MESS UP OIL BEARING CLEARENCES? (ejcivicdee)
Micropolishing is just that, Polishing. Its so minimal that it shouldnt throw your clearances off. Bearing clearances wont change unless you were grind the crank.
Old May 26, 2005 | 07:07 PM
ejcivicdee's Avatar
Default Re: Please HELP!!!! MICROPOLISHING CRANK MESS UP OIL BEARING CLEARENCES? (SlowReaction)
thanks, thats what i thought. Some guy was saying in some thread that if you mico polish your crank it will totally through off your oil bearing clearence, but i guess he was wrong.
Old May 26, 2005 | 09:54 PM
IN VTEC's Avatar
You'd really have to go long and hard at it to remove more than .0003" at a time off a single journal on a Honda crankshaft because they're hardened.
In fact, you're not supposed to take a lot out on a micropolish without a properly-constructed abrasive belt. It'll belly down the centerline of the journal because it takes more out of the middle than the outer edges (towards the fillets).
My experience with micropolishing is that after two micropolishes, the journals were about .0003" to .0004" smaller than before having them polished. I had to polish the journals twice because the first place didn't deburr the teardrop & chamfer they put on the oil feed holes.
Old Mar 27, 2006 | 09:05 AM
b20vtechatch
Guest
Posts: n/a
Default Re: Please HELP!!!! MICROPOLISHING CRANK MESS UP OIL BEARING CLEARENCES? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">You'd really have to go long and hard at it to remove more than .0003" at a time off a single journal on a Honda crankshaft because they're hardened.
My experience with micropolishing is that after two micropolishes, the journals were about .0003" to .0004" smaller than before having them polished. I had to polish the journals twice because the first place didn't deburr the teardrop & chamfer they put on the oil feed holes.</TD></TR></TABLE>
What about machining your rods for arp bolts? Can i still use acl std. bearings for the rods too?
Old Mar 27, 2006 | 03:38 PM
IN VTEC's Avatar
Default Re: Please HELP!!!! MICROPOLISHING CRANK MESS UP OIL BEARING CLEARENCES? (b20vtechatch)
You'll just have to measure after honing.
Old Mar 30, 2006 | 07:38 AM
b20vtechatch
Guest
Posts: n/a
perfect
im going with acl . clearences are just what i wanted
carlossolorzano
May 30, 2012 06:43 AM
dallasyoung
Nov 2, 2011 04:53 PM
jbrokos307
13
Oct 21, 2009 05:51 AM
xxmastermindxx
May 6, 2007 09:17 AM
BUSAFREAK
Sep 25, 2001 10:23 AM
