92 civic TOE ADJ PROBLEM HELP!
MY rear wheel is jacked up. the front portion of my wheel in the rear is sticking out. i tried to find out if something was bent, but couldnt find anything. have u guys ever had this problem let me know thanks
i had the opposite happen to me... i did a rear disc conversion from a gsr and my rear tires are toed in... ive already moved the trailing arm out as far positive as it will go but they are still toed in... they wear out way faster than the fronts do... im gonna need adjustable toe links in the rear and then an alignment
88 civic ef
13
Jan 2, 2008 04:31 AM
