Springs and Rim size
Old May 26, 2005 | 01:01 PM
ShadyHaitien's Avatar
Default Springs and Rim size
Currently I'm on Neuspeed Race springs with some 14" rims, but I just bought some 17" rims, will these fit with the race drop or will I have to switch to the Neuspeed Sport springs.
Thanks in advance.
**forgot to mention: 97' EX coupe
Old May 26, 2005 | 01:06 PM
neutron91's Avatar
Default Re: Springs and Rim size (ShadyHaitien)
you will probably rub your tires... get some 15's
Old May 26, 2005 | 01:14 PM
Default Re: Springs and Rim size (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">you will probably rub your tires... get some 15's</TD></TR></TABLE>
Yeah thats what I was thinking, I really like these rims though...
Anyone rocking 17s, what is a comfortable drop? 1.5"?
Old May 26, 2005 | 01:43 PM
neutron91's Avatar
yeah if you had coilovers you could atleast raise it back up to where your tires will clear... with springs youre just stuck with what you got
Old May 26, 2005 | 02:05 PM
dantastic's Avatar
depends on tire size and offset. but most likely, you will rub (esp on the inside fender when at full lock)
Old May 27, 2005 | 04:42 AM
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">yeah if you had coilovers you could atleast raise it back up to where your tires will clear... with springs youre just stuck with what you got</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">depends on tire size and offset. but most likely, you will rub (esp on the inside fender when at full lock)</TD></TR></TABLE>
Put them on, they fit fine, when the car is not moving I can turn the front wheels with no clearance issues... But driving is a whole different story, lol. Only took it around the block, on turns any little bump in the road and they rub... So the stock springs will be going back on for now... BTW the tire size is 205/40, and the offset is 40... I think I may go with the Omni Power coilovers, any suggestions?
Old May 27, 2005 | 06:10 AM
vtec95sol's Avatar
roll your fenders.
asianalbutt
Jan 10, 2006 09:37 AM
sohctodohc
Suspension & Brakes
15
Sep 16, 2005 12:07 AM
Tuesdaynightfever
May 29, 2005 11:50 PM
vteckiller
Feb 17, 2004 11:05 PM
98blkaccord
Jun 19, 2003 04:55 PM
